Hopefully someone can help me or has had this issue before.
68 roadrunner. I converted it to PS a few months ago. Box is from my 74 challenger, was a sound box before i swapped to manual .
I had a Trw pump i threw on, it worked, no noises. But it leaked like crazy and also felt WAY over assisted. I had some saginaws laying around.
Converted it to a Saginaw. Not sure off what, could of been mopar or GM but they all look similar and bolt up. Every thing was fine for a few days . Until today I saw the belt was a little loose so i snugged it up. Geez , After i did that the pump started whining and gets louder as rpm climbs. Thought bad pump ( it was used) put on another used , same thing. Put a 3rd pump on . Same deal! Im using normal PS fluid, belts snug.
What should I check next? Could the pressure line be collapsed internally like a brake hose? No bubbles in the fluid when running. Any suggestions would be appreciated! Thanks!
