Page 2 of 7 1 2 3 4 5 6 7
Re: The turbo Cuda build has begun [Re: go green] #180183
01/02/09 11:47 PM
01/02/09 11:47 PM
Jarrettsville, MD
cudaman1967 Offline OP
Jarrettsville, MD
Ha! Quick and Dirty at a final at capitol last year to mess with the chevy guys!
Cudaman1967 1967 Barracuda Turbo Outlaw 8.50
Re: The turbo Cuda build has begun #180184
01/02/09 11:51 PM
01/02/09 11:51 PM
Jarrettsville, MD
Jarrettsville, MD
Kevin at CSU is doing a dominator for it. That is my alcohol Dominator on it that I bracket race with for mocking up.
Gasoline on the street with water/meth injection, race gas at track. 15-20psi at the track, 8psi around town. You will start to see more and more dominators as time goes on. They are starting to find they work well even on lower HP motors (1000hp or less)
Re: The turbo Cuda build has begun [Re: cudaman1967] #180185
01/03/09 08:49 AM
01/03/09 08:49 AM
Jarrettsville, MD
Jarrettsville, MD
Both headers built and crossover pipe
Re: The turbo Cuda build has begun [Re: cudaman1967] #180186
01/03/09 08:51 AM
01/03/09 08:51 AM
Jarrettsville, MD
Jarrettsville, MD
merger pipe
Re: The turbo Cuda build has begun [Re: cudaman1967] #180187
01/03/09 08:52 AM
01/03/09 08:52 AM
Jarrettsville, MD
Jarrettsville, MD
merger pipe #2. Thats it for now heading up to work on car.
Re: The turbo Cuda build has begun [Re: cudaman1967] #180188
01/03/09 10:07 AM
01/03/09 10:07 AM
Re: The turbo Cuda build has begun #180189
01/03/09 11:48 AM
01/03/09 11:48 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
is that all stainless?
Re: The turbo Cuda build has begun [Re: joshking440] #180190
01/03/09 01:17 PM
01/03/09 01:17 PM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
Sweet build !!! Please keep us posted!! Ive have wanted to and will build a turbo big block in the next year or so.
www.sikosracing.net Heads up Drag racing
Re: The turbo Cuda build has begun [Re: moparmattkos] #180191
01/03/09 09:02 PM
01/03/09 09:02 PM
Jarrettsville, MD
Jarrettsville, MD
Radiator bottom mount made need to complete tomorrow
Re: The turbo Cuda build has begun [Re: cudaman1967] #180192
01/03/09 09:03 PM
01/03/09 09:03 PM
Jarrettsville, MD
Jarrettsville, MD
Wastegate
Re: The turbo Cuda build has begun [Re: cudaman1967] #180193
01/03/09 09:04 PM
01/03/09 09:04 PM
Jarrettsville, MD
Jarrettsville, MD
BOV
Re: The turbo Cuda build has begun [Re: cudaman1967] #180194
01/03/09 10:36 PM
01/03/09 10:36 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
How big is that wastegate?
Same for the BOV?
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!) 03 Mach1
Re: The turbo Cuda build has begun [Re: cudaman1967] #180195
01/03/09 10:49 PM
01/03/09 10:49 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Looks good! Good thing you left room for another turbo. My guess is you'll be adding another once you get that setup working.
Here's a video of a rear mounted twin turbo we tuned recently.
http://www.youtube.com/watch?v=lQugsN1ucZo
I'm hooked. Looking to put twin trunk mounted ht60's on the GTX once I get this 446 up and running. Planning on going blow through on a dominator also. Please keep us posted on your progress.
Re: The turbo Cuda build has begun [Re: tilt] #180196
01/03/09 10:59 PM
01/03/09 10:59 PM
Jarrettsville, MD
Jarrettsville, MD
60mm, 50mm
Re: The turbo Cuda build has begun [Re: RyanJ] #180197
01/03/09 11:28 PM
01/03/09 11:28 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
Wow Ryan is alive, I guess he's to busy working on turbos to return customers calls,
Re: The turbo Cuda build has begun [Re: mokid] #180198
01/04/09 02:00 PM
01/04/09 02:00 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Your wide band O2 sensor bung is too close to your turbo, you will barbecue it in not time at all.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: The turbo Cuda build has begun [Re: go green] #180199
01/04/09 02:20 PM
01/04/09 02:20 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
look how far it is away from the cylinder head.normal distance.
Re: The turbo Cuda build has begun [Re: blownzoom440] #180200
01/04/09 03:19 PM
01/04/09 03:19 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
Mine were same distance... I had two bungs, one for my ecu and a second for LM1. Never had a problem.
"These go to eleven", Nigel Tufnel
Re: The turbo Cuda build has begun [Re: cudaman1967] #180201
01/05/09 12:10 PM
01/05/09 12:10 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Turbo is located and passenger header is built. Friday will build the drivers side.
where are you gonna put the radiator???
Re: The turbo Cuda build has begun [Re: Mr.Yuck] #180202
01/05/09 12:22 PM
01/05/09 12:22 PM
Jarrettsville, MD
Jarrettsville, MD
Its in the picture above but I have more photos to post from yesterday that show it a little better.
