Re: Stopped by Thumpers
[Re: littleVAL]
#1801422
04/12/15 12:39 AM
04/12/15 12:39 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
That carb looks sexy. Wish I got one like that now
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1801671
04/12/15 01:43 PM
04/12/15 01:43 PM
Thumperdart
State of confusion
That carb looks sexy. Wish I got one like that now Yours is bad azz so no worries Ray...........
[Re: littleVAL]
#1801793
04/12/15 05:04 PM
04/12/15 05:04 PM
Thumperdart
State of confusion
Hey Don thankxxx 4 posting these pics and was curious if you could post the rear end shots for those that asked about my sliders and shock relocation.......
[Re: mopar65]
#1802186
04/13/15 02:31 AM
04/13/15 02:31 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Dom i cant be leave you are still running that little wimpy 8-3/4.better not let QuickTree see that.lol sorry just trying to be funny. Dom when you moved your upper shock mount what did you use for the bolt, the upper shock stud? i see you cut little holes so you can get to the stud/bolts. sorry for the dumb question, i want to try this on my duster.also looking at the pics you had to notch the rear frame for the sliders right? got any pics on how you did the front spring box? thanks mopar65 If you do.. turn the shock 90* so its in line with the rotation, it takes a bit more work.. just weld on 2 brackets to the cross member at the proper width for the shock... it will work like Dom has it but thats the way they are mounted for corners like in the original position
[Re: mopar65]
#1802311
04/13/15 12:22 PM
04/13/15 12:22 PM
Thumperdart
State of confusion
Yes I used the stock shock bolts and a sleeeve between the sheet metal just like stock and drilled a hole underneath to feed the sleeve then tightned it up and hasn't loosened up yet. I know that I'm on borrowed time and forgive me for the dirt cos my SHACK that I work in is surrounded by a big dirt lot so I have a 4x4 drag car till I hit the streets but not for long cos I'm finally landing in Vegas next month.
Sorry, there's pictures of the ft. segments somewhere in here but I'll try to get some soon from lilval.......
[Re: BradH]
#1804945
04/16/15 02:16 PM
04/16/15 02:16 PM
Thumperdart
State of confusion
... I'm finally landing in Vegas next month. Does the Vegas street scene have a "list"? Funny enuff they do and they're called the bottom ten............and from what videos I have seen I'd be the gatekeeper MAYBE. Greg, I call that my Pimp Station and the chassis shots are embarrassing.......
[Re: mopar dave]
#1805027
04/16/15 04:02 PM
04/16/15 04:02 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Do you have work lined up in Vegas Dom and if so what type? Good-luck on you adventure.
[Re: pittsburghracer]
#1805160
04/16/15 07:45 PM
04/16/15 07:45 PM
Thumperdart
State of confusion
Do you have work lined up in Vegas Dom and if so what type? Good-luck on you adventure. Im going to see how long it takes for me to make 100,000 dollars doing carbs and flippin cars with my friend plus drumming. Thankxx guys and big things are comin trust me.........
[Re: mopar dave]
#1805183
04/16/15 08:10 PM
04/16/15 08:10 PM
Thumperdart
State of confusion
Thankxxx I land there on may 8th with everything I own and my car is my rolling billboard and always has been............not sure why though. Lol. Just did a box stock 750 holley dp and did the mojo and what a difference and this is on a replica Cobra out of south Africa for THE door man out here ADoor Dave. It's 402 Rouch racing engine that had a whimpy vac sec avenger on it which just doesn't fly for me and he listened and was rewarded with a clean piece.
[Re: mopar dave]
#1805402
04/17/15 01:48 AM
04/17/15 01:48 AM
Thumperdart
State of confusion
Sorry will empty now......
