1970 Dart switched ignition connection on back of fuse block #1801290
04/11/15 09:43 PM
04/11/15 09:43 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
I need to tap into the switched ignition circuit on the back of a 1970 Dart fuse block, which connection is it?
JB Rhinehart, Realist
A-Body's RULE!
Re: 1970 Dart switched ignition connection on back of fuse block [Re: Rhinodart] #1801351
04/11/15 11:04 PM
04/11/15 11:04 PM
the heater would be a good one. either go by the printing on the front where the fuses are or www.mymopar.com will have the colors. EDIT tap in upstream from the fuse so your added draw ain't going thru the heater fuse. I'm assuming you are going to fuse your additions
