69 B-body firewall hole ?? #1801105
04/11/15 04:12 PM
04/11/15 04:12 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
What goes through this hole in a '69 b-body (Plymouth) ?? Right above the throttle cable hole.
Re: 69 B-body firewall hole ?? [Re: Stanton] #1801187
04/11/15 07:08 PM
04/11/15 07:08 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
the hole on mine was a lot smaller and that's where my ground wire is attached
Re: 69 B-body firewall hole ?? [Re: Stanton] #1801190
04/11/15 07:10 PM
04/11/15 07:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Plastic push-peg hole for the firewall insulation?
Re: 69 B-body firewall hole ?? [Re: Stanton] #1801215
04/11/15 07:41 PM
04/11/15 07:41 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Ground wire was up near the seam and on the other side.
Not a push peg hole - those holes are all dimpled out. This one is flat.
I have a whole bunch of reference photos but wouldn't you know that none are showing this area !!
Re: 69 B-body firewall hole ?? [Re: Stanton] #1801244
04/11/15 08:13 PM
04/11/15 08:13 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
pretty sure the ground goes there and someone made your hole larger. probably should have phrased that differently......
Re: 69 B-body firewall hole ?? [Re: Stanton] #1801274
04/11/15 09:02 PM
04/11/15 09:02 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Hmmm ... note where the grounds are ...
reference 017.jpg (325 downloads)
reference 002.jpg (281 downloads)
Re: 69 B-body firewall hole ?? [Re: Stanton] #1801289
04/11/15 09:43 PM
04/11/15 09:43 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
hmmm.... you seem to be right! well, for what ever reasons mine go to the spot where you have a much larger hole. weird cause my hole is threaded to take that same bolt.
Re: 69 B-body firewall hole ?? [Re: Stanton] #1801449
04/12/15 01:38 AM
04/12/15 01:38 AM
N
NITROUSN Offline
NITROUSN  Offline
N
As John Kunkel said it is a push pin for fire wall insulation.
Re: 69 B-body firewall hole ?? [Re: NITROUSN] #1801450
04/12/15 01:43 AM
04/12/15 01:43 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I want to add a picture but wtf I cant figure out this new system???????????????????????????????????????
Re: 69 B-body firewall hole ?? [Re: Stanton] #1801457
04/12/15 01:58 AM
04/12/15 01:58 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Here is an interior pic.
Re: 69 B-body firewall hole ?? [Re: Stanton] #1801525
04/12/15 08:04 AM
04/12/15 08:04 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Huh ! Ok, can't argue with that. All the other push pin holes are dimpled but not this one. That was throwing me off. Thanks.
Re: 69 B-body firewall hole ?? [Re: Stanton] #1801528
04/12/15 09:08 AM
04/12/15 09:08 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
the push pin theory makes more sense than my ground wire but the hole is way to big now.
Re: 69 B-body firewall hole ?? [Re: Stanton] #1801750
04/12/15 03:36 PM
04/12/15 03:36 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
All those push pin holes are getting flattened and filled anyway - as are most others. Cleaning things up a bit !!
Re: 69 B-body firewall hole ?? [Re: Stanton] #1802018
04/12/15 10:22 PM
04/12/15 10:22 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Well after taking another look there's no doubt that at one time it was a push pin hole which I must have enlarged to run wires or something through (maybe an oil pressure line). But since I've owned the car for over 40 years, I just don't remember!
