A-Body Interior Rear Floor Moldings (Aluminum) #1801084
04/11/15 03:14 PM
04/11/15 03:14 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Does anyone know if there is a company reproducing the interior A-Body rear floor moldings (LH/RH made of aluminum) that are installed over the carpet and secure to the rear inner side panel? If I recall correctly, the molding interfaces with the sill molding (part shingling). Please reference the attached photos.
Attached PDF document
Re: A-Body Interior Rear Floor Moldings (Aluminum) [Re: vinnyd76] #1801427
04/12/15 12:53 AM
04/12/15 12:53 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Slightly different part on 69 Barracuda, but same problem - no known reproductions. I'm expecting to end up fabricating my own.
Nobody is ever going to get their eye ball very close down there, so a decent copy made from bright aluminum sheet should meet my standards.
