Re: Stock 440 pistons
[Re: cudaman1969]
#1799679
04/09/15 07:54 PM
04/09/15 07:54 PM
RapidRobert
copied from a prior post: 68-69 2.030 CH ~050 in the hole. 67 2.00' CH ~.080 in the hole. low comp 440 book says 1.990 CH but actually its 1.920 (check on that/I may have copied that wrong but iirc the 1.920" part is accurate). 440 six pak 2.060" CH ~ .020 in the hole
[Re: carteravs]
#1800644
04/10/15 09:56 PM
04/10/15 09:56 PM
Posts: 4,320 Prospect, PA
BSB67
Prospect, PA
'68-'69 Piston PN 3004535 Comp. Hgt. 2.026 '70-'71 Piston PN 3420214 Comp. Hgt. 2.005 Both actually measured. Good to know, I've called the 68 - 69 as 2.03" ish, as others have claimed from 2.025" to 2.035", the Old DC book I have has 2.03" but only three significant figures, and my forged NHRA approved 2286P pistons measures 2.033"
