Stock 440 pistons #1799623
04/09/15 07:02 PM
04/09/15 07:02 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Are the 68-71 440 pistons the same compression height, other than the six-pack ones?
Re: Stock 440 pistons [Re: cudaman1969] #1799679
04/09/15 07:54 PM
04/09/15 07:54 PM
copied from a prior post: 68-69 2.030 CH ~050 in the hole. 67 2.00' CH ~.080 in the hole. low comp 440 book says 1.990 CH but actually its 1.920 (check on that/I may have copied that wrong but iirc the 1.920" part is accurate). 440 six pak 2.060" CH ~ .020 in the hole
Re: Stock 440 pistons [Re: RapidRobert] #1799826
04/09/15 10:41 PM
04/09/15 10:41 PM
fredericksburg,va
fredericksburg,va
Thanks, did it say what the 70-71 standard 440 pistons where or are they the same as 68-69
Re: Stock 440 pistons [Re: cudaman1969] #1799841
04/09/15 11:00 PM
04/09/15 11:00 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I believe that the 70 piston is the same, and think the 71 piston is shorter, ie the 1.990 piston. Not 100% sure though. I might be off by one year.
Re: Stock 440 pistons [Re: cudaman1969] #1799914
04/09/15 11:54 PM
04/09/15 11:54 PM
Ohio
carteravs Offline
carteravs  Offline
Ohio
'68-'69 Piston PN 3004535 Comp. Hgt. 2.026
'70-'71 Piston PN 3420214 Comp. Hgt. 2.005
Both actually measured.
Re: Stock 440 pistons [Re: carteravs] #1799935
04/10/15 12:13 AM
04/10/15 12:13 AM
I musta copied it wrong
Re: Stock 440 pistons [Re: carteravs] #1800644
04/10/15 09:56 PM
04/10/15 09:56 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Good to know, I've called the 68 - 69 as 2.03" ish, as others have claimed from 2.025" to 2.035", the Old DC book I have has 2.03" but only three significant figures, and my forged NHRA approved 2286P pistons measures 2.033"
