Center Force clutch #1800001
04/10/15 01:29 AM
04/10/15 01:29 AM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
I bought a Center Force dual friction clutch, and there is nothing in the paper work on what the clearance between the fingers, and the throwout bearing should be. Any of you guys that use one of these know what it should be?
Re: Center Force clutch [Re: 71birdJ68] #1800058
04/10/15 08:21 AM
04/10/15 08:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Slide the disc against the flywheel. Get a .060" feeler gauge between the disc and pressure plate.
Doug
Re: Center Force clutch [Re: 71birdJ68] #1800115
04/10/15 11:02 AM
04/10/15 11:02 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Per the FSM ... about 1/8" free play between the fork and the rod.
Re: Center Force clutch [Re: Stanton] #1800179
04/10/15 12:20 PM
04/10/15 12:20 PM
Morristown Tn.
Morristown Tn.
Are you sure? The service manual is talking about a Bourg, and Beck with an over center spring, this is a diaphragm without a over center spring. I know Mcleod says 1/8 to 1/4 between the fingers, and the throwout bearing. But Centerforce doesn't say anything, and when I call they just said follow the service manual, but that was for a Chevy.
Re: Center Force clutch [Re: 71birdJ68] #1800194
04/10/15 12:28 PM
04/10/15 12:28 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
.060" is the standard, but with my experience, as long as the throwout bearing is NOT riding on the pressure plate and when you push the clutch pedal in, you can shift gears easily, you are good to go. Usually you will have about 1/4" free play at the clutch fork and about 1 1/2" of pedal travel up top. My 2 cents. Good luck.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Center Force clutch [Re: 71birdJ68] #1800294
04/10/15 02:26 PM
04/10/15 02:26 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Borg & Beck or diaphram ... why should it matter ?!?!?!
1/4 at the fork and 1-1/2 at the pedal is excessive (in my opinion). Too much play can result in inadequate clutch release which equates to wear. As previously stated, I shoot for 1/8 at the fork and that gives about 1" at the pedal.
Re: Center Force clutch [Re: 71birdJ68] #1800307
04/10/15 02:39 PM
04/10/15 02:39 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Centerforce IS a Chivvy clutch, give me Borg & Beck or give me death! catfight
JB Rhinehart, Realist
A-Body's RULE!
Re: Center Force clutch [Re: Rhinodart] #1800322
04/10/15 02:54 PM
04/10/15 02:54 PM
I use to shoot for .030 on the feeler gauge bewteen the clutch disc and pressure plate or flywheel on RACE DISCs, Most Mopars wth B&B clutches will work well with .060 to .125 between the throw out bearing and prsesure plate fingers. I put a new Center Force clutch set in my 1969 Dart GTS last year, I need to remove the over center spring now to get the clucth pedal to not stick 7/8 the way up from releasing.
Re: Center Force clutch [Re: 71birdJ68] #1800328
04/10/15 03:01 PM
04/10/15 03:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If you havent run one dont knock them.They are a great clutch I never measure.Just adjust till I can shift into Reverse easy as soon as it does its set.Clutches last a long time doing that.The CF I have now is about 15 years old and still flawless.rocky
Chrysler Firepower
Re: Center Force clutch [Re: therocks] #1800364
04/10/15 03:40 PM
04/10/15 03:40 PM
dogdays Offline
dogdays  Offline
Most of the experienced posters are right, IMHO. As long as the throwout bearing is not riding on the clutch fingers, whatever style, it has enough clearance. I don't measure, just set it up to touch and then back off a little.
As far as clutch design goes, I associate Long style pressure plates with Ford. But Chrysler and GM have both been using Borg&Beck and diaphragm clutches for years and years. Neat thing about them is the bolt pattern is the same so they can interchange.
Another neat thing (mainly for trucks) is with an 11" clutch you can upgrade to a 12" disk just by buying the 12" clutch set, it's a bolt-on. This is for the 143 and more tooth flywheel.
The 12" Borg&Beck in my '64Dog is a McLeod, but there was also a rebuilt 12" B&B from an early '60s chevy truck that I was watching on ebay. Turns out the McLeod was just a few dollars more, so my pressure plate is now red rather than blue.
R.
Re: Center Force clutch [Re: therocks] #1800367
04/10/15 03:42 PM
04/10/15 03:42 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Exactly what I was trying to say. Don't get too caught up on measurements. This isn't rocket science.......
Re: Center Force clutch [Re: 71birdJ68] #1800522
04/10/15 07:32 PM
04/10/15 07:32 PM
Morristown Tn.
Morristown Tn.
The reason I'm asking is cause Centerforce won't give any specks. Now here is what Mcleod told me on the phone about their diaphragm clutch. If the throwout bearing is to close to the fingers, they will start going over center, and re in-gauging the disc which is not good.
Re: Center Force clutch [Re: therocks] #1800634
04/10/15 09:42 PM
04/10/15 09:42 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Oh I have tried the weak-feeling clutches a couple of times, hated them. tsk Maybe when my knees finally go I will have to use one, but I still like the feeling of a clutch that matches the rest of the drivetrain... boogie
A-Body's RULE!
Re: Center Force clutch [Re: 71birdJ68] #1800635
04/10/15 09:42 PM
04/10/15 09:42 PM
The main bad thing about diaghram type clutches is when racing and speed shifting them is if they go over center the clutch pedal sticks to the floor with the clutch disengaged, NOT GOOD AT ALL. Been there, done that, more than once when driving(street racing) someone elses Chevy car back in the day, never ever had that happen with BB or Long style clutch.
Re: Center Force clutch [Re: Cab_Burge] #1800757
04/10/15 11:58 PM
04/10/15 11:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've been wailing on my Center-Force for over 10 years. 7000 rpm shifts. Never sticks, best shifting A-833 I've ever had.
Doug
Re: Center Force clutch [Re: 71birdJ68] #1800787
04/11/15 12:18 AM
04/11/15 12:18 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The last Centerforce clutch I bought lasted <30 days, a big POS...
It went into the dumpster..
Now all we run are McCleod Borg & Beck, a little old school and takes more pedal pressure to disengage but they work well..
Just my $0.02... wink
Re: Center Force clutch [Re: 71birdJ68] #1800923
04/11/15 10:18 AM
04/11/15 10:18 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
dvw I do the same with mine I usually shift at 6800 to 7200.Never had a problem.I had a 3400 pound McCleod in it before.The CF bites better and is light to hold.30 days you should have sent it back.Rocky
Chrysler Firepower
Re: Center Force clutch [Re: therocks] #1801255
04/11/15 08:28 PM
04/11/15 08:28 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
After blowing up a couple of B & B clutches in my Road Runner, I removed the over-center spring and put a Centerforce in. I was very happy with Centerforce. Light pedal pressure, bites hard, shifts were improved. I'm a believer.
As for the spacing on the TO bearing, I just make sure it is not riding the forks all the time and adjust for pedal free play.
Re: Center Force clutch [Re: Sinitro] #1801393
04/11/15 11:39 PM
04/11/15 11:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It lasted only 30 days? What happened to it? Mine has at least 100 passes with slicks. No rocket but a nice street car runs 12.50@110. I've beat this clutch as hard as any I've ever owned. I never had a clutch go more than a year or so until this one.
Doug
Re: Center Force clutch [Re: dvw] #1801881
04/12/15 07:49 PM
04/12/15 07:49 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Just how far does the throwout bearing have too go once it makes contact with the diaphragm to disengage the clutch? There must be a measurement but I haven't found one. You can't go over center with a Center Force because the weights on the fingers will contact the clutch disk first. That is from the Center Force diagnostics guide. I run a centerforce in my cuda and one in my SRT-10. Love the 'Cuda clutch hate the SRT-10. Difference? The 'Cuda is all manual linkage the SRT-10 is hydraulic.
