Option code location #180037
12/31/08 10:02 PM
12/31/08 10:02 PM
70duster340 Offline OP
Where are these located on a 2007 Dakota? I am looking for the axle code. I have a 4X4 quad cab, with the 4.7 HO, and 3.92 axle ratio. I am curious as to the size of the axle. Is it an 8.25, or larger? My former 2002 Dakota 4X4 quad cab had a 4.7 also, with the 3.55 axle ratio, but the rear axle was the 9.25. Did Chrysler stop installing the 9.25 in the Dakotas?
Re: Option code location [Re: 70duster340] #180038
12/31/08 10:06 PM
12/31/08 10:06 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If they are the same as the full size trucks, look on the front of the radiatior support.
Re: Option code location [Re: Alaskan_TA] #180039
12/31/08 10:23 PM
12/31/08 10:23 PM
Thank you, sir! I will check there.
Re: Option code location [Re: 70duster340] #180040
01/01/09 06:32 PM
01/01/09 06:32 PM
Well, I appreciate the info, but it isn't located on the front of the radiator support. Anybody else have any ideas or tips?
Re: Option code location [Re: 70duster340] #180041
01/01/09 06:36 PM
01/01/09 06:36 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
My 2003 Durango codes are on a sticker in the glovebox. Not sure if that helps.
Craig
Re: Option code location [Re: denfireguy] #180042
01/01/09 06:50 PM
01/01/09 06:50 PM
Where at in the glovebox? On the door, or actually inside the box itself?
Re: Option code location [Re: 70duster340] #180043
01/02/09 12:04 AM
01/02/09 12:04 AM
Maybe a tech can chime in here???
Re: Option code location [Re: 70duster340] #180044
01/02/09 11:40 AM
01/02/09 11:40 AM
C'mon, any techs here willing to help?
Re: Option code location [Re: 70duster340] #180045
01/02/09 05:58 PM
01/02/09 05:58 PM
Well, I have searched the inside of the glove box, inside the console (removing the plastic CD holder, too), and checked all 4 doors. So far I have not found anything. Are there any techs that would be able to help?
Re: Option code location [Re: 70duster340] #180046
01/02/09 06:38 PM
01/02/09 06:38 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
What about somewhere behind the seat on the cab, doesn't it have storage areas behind the seat?
Re: Option code location [Re: 4BBodies] #180047
01/02/09 06:39 PM
01/02/09 06:39 PM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
Dakota.............sorry...............try the rear panels near the spare tire?
Re: Option code location [Re: 4BBodies] #180048
01/02/09 06:43 PM
01/02/09 06:43 PM
There is a storage area behind the rear seat (it's a Quad Cab). I didn't check there. But near the spare tire carrier? That's actualy under the truck. Could it be there?
Re: Option code location [Re: 70duster340] #180049
01/02/09 08:45 PM
01/02/09 08:45 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
call a chrysler dealer parts dept with the vin,they can tell you what axle it is
butch
Re: Option code location [Re: 70duster340] #180050
01/02/09 09:01 PM
01/02/09 09:01 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Just look underneath it
The 9.25 cover looks like a stop sign, the 8.25 is noticable smaller and flat on top and bottom.
