Stealth head plug choice? #1800250
04/10/15 01:42 PM
04/10/15 01:42 PM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
I've looked at their site and I can't find anywhere that it mentions it, but do Stealth heads require a longer or shorter plug than stock? I've always run Autolite 85's in big blocks, will they work?
Thanks.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Stealth head plug choice? [Re: OhioMopar] #1800331
04/10/15 03:02 PM
04/10/15 03:02 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
They use a long reach plug just like Eddys.I have an NGK number here I run but Im at 12.5 compression.Rocky
Chrysler Firepower
Re: Stealth head plug choice? [Re: therocks] #1800339
04/10/15 03:14 PM
04/10/15 03:14 PM
dogdays Offline
dogdays  Offline
They use a long reach gasketed plug like LA motors.
So call it a 340 plug and go shopping. I use Rockauto to check out plugs.
R.
Re: Stealth head plug choice? [Re: OhioMopar] #1800342
04/10/15 03:16 PM
04/10/15 03:16 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
So the 85's should work?
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Stealth head plug choice? [Re: dogdays] #1800344
04/10/15 03:19 PM
04/10/15 03:19 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Will do. Thanks! up
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Stealth head plug choice? [Re: OhioMopar] #1800353
04/10/15 03:29 PM
04/10/15 03:29 PM
dogdays Offline
dogdays  Offline
No, the 85 and 86 are short reach gasketed plugs used on B/RB engines and also on my 318 Poly engine. Threads are approximately 3/8" long.
Look up a 340 plug to get the difference. They have thread length of approximately 3/4", thus are called long reach plugs.
BTW, long reach plugs are much easier to find at your local Walmart than short reach gasketed plugs. For years they were all one would find in an aluminum head.
Re: Stealth head plug choice? [Re: dogdays] #1800358
04/10/15 03:32 PM
04/10/15 03:32 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Gothcha. Thanks again.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Stealth head plug choice? [Re: OhioMopar] #1800397
04/10/15 04:31 PM
04/10/15 04:31 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Last NGK race plugs I bought at Advance cost me under 15 bucks for 8 I do get a shop discount.Rocky
Chrysler Firepower
Re: Stealth head plug choice? [Re: OhioMopar] #1800590
04/10/15 08:50 PM
04/10/15 08:50 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if your autolite guy try 3924 or 3926(hotter).
Re: Stealth head plug choice? [Re: OhioMopar] #1800606
04/10/15 09:10 PM
04/10/15 09:10 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Why not just grab the correct set from 440 Source. They sell them as well and are the correct ones for their heads....
Re: Stealth head plug choice? [Re: lewtot184] #1802244
04/13/15 08:50 AM
04/13/15 08:50 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
So 65's are the wrong heat range?
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Stealth head plug choice? [Re: CR8CRSHR] #1802245
04/13/15 08:52 AM
04/13/15 08:52 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
So, order plugs from Nevada when I can pick them up on the way hom3 from work? Seems a bit counterproductive. I did find they had a listing for plugs, but they are under a Source part number, not a Champion #.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Stealth head plug choice? [Re: OhioMopar] #1802266
04/13/15 10:13 AM
04/13/15 10:13 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
have no idea what a "65" is. i use the 3924 and 3926 in my edelbrock heads. easy to find and work fine.
Re: Stealth head plug choice? [Re: OhioMopar] #1802436
04/13/15 03:03 PM
04/13/15 03:03 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Autolite 65. It's the one I've always used in small blocks. I'll look up the 3924/3926. Thanks.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Stealth head plug choice? [Re: OhioMopar] #1802464
04/13/15 03:47 PM
04/13/15 03:47 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
The plugs they sell are the Champion plugs. I get your point but for me when I purchased my heads I threw a set in with the purchase along with the 10 degree locks for the spring retainers. Everything in one check out basket if you catch my drift...cr8crshr/Bill
Re: Stealth head plug choice? [Re: lewtot184] #1802471
04/13/15 04:03 PM
04/13/15 04:03 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
ok. all i do is big block stuff. a 65 is probably a 13/16" hex and the 3924 is a 5/8" hex. the 5/8" will probably be easier to work with.
