Page 1 of 3 1 2 3
AV GAS #1797289
04/07/15 12:44 PM
04/07/15 12:44 PM
State of confusion
Thumperdart Offline OP
State of confusion
Just curious if any of you folks run it and how it compares to race gas.
Re: AV GAS [Re: Thumperdart] #1797314
04/07/15 01:11 PM
04/07/15 01:11 PM
an8sec70cuda Offline
Ran it for years in a 12.5:1 440 and never had any problems. Ran as good as VP 110 in that motor.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: AV GAS [Re: an8sec70cuda] #1797438
04/07/15 02:53 PM
04/07/15 02:53 PM
State of confusion
State of confusion
That's what I have been hearing. .......Thankxx
Re: AV GAS [Re: Thumperdart] #1797547
04/07/15 04:28 PM
04/07/15 04:28 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
Been running it for years. Car runs the same as it did on Sunoco 110 . 11.2:1 engine . I always mix in a little Lucas top end lube with it .
Re: AV GAS [Re: Thumperdart] #1797640
04/07/15 05:47 PM
04/07/15 05:47 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Back before I could afford a HEMI, I built like, 12 BB Chevys. Always used the "Bible", How to Build a Big Block Chevy. I wore out the first one. It often quoted Chevy engineers. They RECOMMENDED AV gas if racing gas was not available. I ran it for years, (worked at the airport and took flying lessons). Never had a problem in 12:1 L-88 and LS7s.
Re: AV GAS [Re: Thumperdart] #1797657
04/07/15 05:58 PM
04/07/15 05:58 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I always use to put it in the challenger when I was racing the car. A guy that works on lawnmowers just told me to use it whenever possible instead of pump gas
Re: AV GAS [Re: sixpackgut] #1797728
04/07/15 07:07 PM
04/07/15 07:07 PM
State of confusion
State of confusion
Should be in Vegas next month and don't want to mess with E 85 so figured I'd try some.
Re: AV GAS [Re: Thumperdart] #1797743
04/07/15 07:28 PM
04/07/15 07:28 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Aviation gas is formulated for low rpm engines at higher altitudes and does not have the BTUs race gas can produce. It sure is better than pump 93 octane that's for sure. It has very different specific gravity also that must be accounted for when tuning. [url=http://www.automotiveu.com/racevsav.htm][/url]
Anyone know what this is?
I'm turning 2300 rpm and it's almost redlined on 100LL!
http://i21.photobucket.com/albums/b260/challenger19711/After%2012-8-14/IMG_52541.jpg
Re: AV GAS [Re: Thumperdart] #1797750
04/07/15 07:34 PM
04/07/15 07:34 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you are wasting your time
Re: AV GAS [Re: super451b] #1797756
04/07/15 07:45 PM
04/07/15 07:45 PM
Cincinnati, Ohio
Cincinnati, Ohio
What's the purpose on the upper lube?
Re: AV GAS [Re: Thumperdart] #1797765
04/07/15 07:55 PM
04/07/15 07:55 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
AV gas is all I use . Since 95 I have not used anything else . No issues at all . Gary
Re: AV GAS [Re: Challenger 1] #1797887
04/07/15 09:59 PM
04/07/15 09:59 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
To be honest , I really dont know. When I made the switch , it was at the recommendation of friends that had been running it for years . They told me to add the lube ,so as a matter of practice, I have always used it .
Re: AV GAS [Re: super451b] #1797899
04/07/15 10:08 PM
04/07/15 10:08 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
AV is the only gas that's been in my Hemi.
Re: AV GAS [Re: Thumperdart] #1797961
04/07/15 10:39 PM
04/07/15 10:39 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
So do you guy's know someone at the airport? the air ports I've been to have the area all fenced in and you have to go through the building , then through a locked door. If you don't have a plane, you don't get passed that door.
Re: AV GAS [Re: rowin4] #1798170
04/08/15 12:45 AM
04/08/15 12:45 AM
australia
charger410 Offline
charger410  Offline
australia
That's what it's like over here now. I used to use it in a 282ci hemi 6 with 12.9 comp, solid lifter engine. Ran Best with 50/50 mix 98pump (your 93) and Av Gas. The motor felt slightly less responsive with straight Av Gas probably because it's a slower burning fuel.
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: AV GAS [Re: Challenger 1] #1798192
04/08/15 01:12 AM
04/08/15 01:12 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I am calling BS on that, if you look at the piston velocities of a Pratt 4360, its equivalent to a SBC at 8000+ rpms. Its not about RPM's it about piston speed.....and at 4500 foot above sea level altitude, our regular gas is only 85 octane...oh and 130-145 octane avgas burns slower than 100 low lead. Your continental or Lycoming engine with a 5" stroke has a lot of velocity and is running at 85% power for hours on end, not something that a car engine typically does. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: AV GAS [Re: rowin4] #1798195
04/08/15 01:14 AM
04/08/15 01:14 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Bring some cans and tell them you want to buy some gas, the fuel sellers at the airport need to sell fuel to pay their insurance...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: AV GAS [Re: Thumperdart] #1798208
04/08/15 01:26 AM
04/08/15 01:26 AM
Salem
Grizzly Online tonguue
Moparts Proctologist
Grizzly  Online Tonguue
Salem
I've been using LL forever.
30% Av to 87 Octane has been working perfect for me.
Why am I using 87 to blend with LL instead of 91? I don't trust that Premium at the pumps is fresh or really premium at all when you hear about the little stories told from guys at the refineries and Truckers that haul it, so I don't bother with it.
Mo' Farts
Moderated by "tbagger".
Re: AV GAS [Re: Thumperdart] #1798221
04/08/15 01:37 AM
04/08/15 01:37 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
The sell E85 at the Rebel stations in Vegas. Tony (70aarcuda) has three race cars running on it. Al might even have a 4500 E85 carb he might sell..... just a thought.
Re: AV GAS [Re: J_BODY] #1798283
04/08/15 02:52 AM
04/08/15 02:52 AM
State of confusion
State of confusion
No desire to run E 85 at this point or I would build my own carb but who knows down the road.
Page 1 of 3 1 2 3
