1970 rr help #179756
12/31/08 03:06 PM
12/31/08 03:06 PM
USA
hemipowered2 Offline OP
USA
my road runner leafspring still won't hook up. i bought all after market parts, and im 1/2 inch from hooking up. do i redrill the holes in the hangers to fit the springs. or keep paying for someone to stare at it for anouther 10 hrs???
Re: 1970 rr help [Re: hemipowered2] #179757
12/31/08 03:09 PM
12/31/08 03:09 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
How about a break down of the parts you bought. If you have super stock springs and are trying to use O.E.M hangers this may very well be your problem.
Re: 1970 rr help [Re: rrunner] #179758
12/31/08 03:21 PM
12/31/08 03:21 PM
USA
USA
im using a set of springs from spings and things they are the hemi ones.. not the super stocks. the hangers are a stock replacement.
Re: 1970 rr help [Re: hemipowered2] #179759
12/31/08 03:33 PM
12/31/08 03:33 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Where exactly does it not fit? The rear of the spring or the front of the spring? I'm not sure what you're talking about.
The rear suspension should have enough play to move the springs side to side to get everything hooked up? 1/2 inch isn't that far??
CHECK OUT MY NEW WEB SITE !
Re: 1970 rr help [Re: hemipowered2] #179760
12/31/08 03:35 PM
12/31/08 03:35 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
If everything came from them I would contact them about it first. Never used anything from them myself.
Re: 1970 rr help [Re: anlauto] #179761
12/31/08 04:22 PM
12/31/08 04:22 PM
USA
USA
its the front to the back. it won;'t hook into the shackel mount its too far forward. i need to know if removing the tube and moving it forward by 1/2 inch is the right thing to do.....
Re: 1970 rr help [Re: hemipowered2] #179762
12/31/08 04:48 PM
12/31/08 04:48 PM
Va
junkman Offline
junkman  Offline
Va
i think you need to put rear end housing and springs together then mount the front of the spring to front spring hanger location,then take a jack and jack up the assembly by the center of housing and this should relax the spring to get that extra 1/2" you need, i've had to do this on a couple of sets of superstock springs to get them to hook up. hope this helps
Re: 1970 rr help [Re: junkman] #179763
12/31/08 06:03 PM
12/31/08 06:03 PM
the junk man is right!!!
Re: 1970 rr help #179764
12/31/08 06:53 PM
12/31/08 06:53 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It's way easier to get the old flat springs out than to get the new arched ones in. I've had to put the front bolt in, push the rear shackle as far forward as you can, and put a floor jack under the spring to flatten it a bit. Make sure you don't lift the car off its jack stands.
Re: 1970 rr help [Re: topside] #179765
12/31/08 08:10 PM
12/31/08 08:10 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Maybe you can back the nuts off the front spring hangers until they are flush with the ends of the studs, then pry the hangers rearward to hook up the rear shackels, then tighten the front spring hanger studs back up?
jt
Yeah, it's hopped up to over 160...
Re: 1970 rr help [Re: jt4406] #179766
01/01/09 09:03 PM
01/01/09 09:03 PM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
you may have dodge springs. they are longer than plymouth.
Re: 1970 rr help [Re: lokalik] #179767
01/02/09 10:49 AM
01/02/09 10:49 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Re: 1970 rr help [Re: 62maxwgn] #179768
01/02/09 11:04 AM
01/02/09 11:04 AM
USA
USA
i took the same springs and put them on a 1970 rr that had never had the rails changed in. and they went right in. thats why im lost when i go to install them in my car. the rear cross member seems to be dead i just don't understand why i cant reach the shackle holes with out moving the holes forward. the springs seem to be short. but if they went right into anouther 1970 rr id say somethings wrong with my frame rails or my shackle mounts. the do sell ones for a station wagon i heard were different. im sure i have the right ones here.
Re: 1970 rr help [Re: hemipowered2] #179769
01/02/09 11:47 AM
01/02/09 11:47 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Do you have your old springs laying around anywhere to compare them to? You might want to measure along the arc of the spring and see if what you received is indeed too short. When I bought replacement springs from ESPO they went right in.
Re: 1970 rr help [Re: hemipowered2] #179770
01/02/09 12:21 PM
01/02/09 12:21 PM
Gladstone, Michigan
UP FM3challenger Offline
Gladstone, Michigan
were the rails replaced along with the rear crossmember?
Re: 1970 rr help [Re: UP FM3challenger] #179771
01/02/09 01:23 PM
01/02/09 01:23 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
It sounds like the springs must be incorrect. I cannot imagine moving the hole in the frame for the rear shackle to bolt up! That would just be jury-rigging it to fit instead of solving the problem. Once installed, the hole in the spring leaf for the rear shackle should actually be a little past the center of the hole for the shackle in the frame. The rear shackle angle from the frame to the spring has to be angled back like in the attached photo so that the shackle can rotate forward on takeoff for the springs to work properly. If you bolt up your front hangers and jack the rear up, the rear shackles should fit relatively easily. If your shackle is laying all the way back and still is missing the hole by a 1/2", you have a problem with the length of the springs or the frame. Even if it bolted up, if the rear spring eye is in front of the mounting hole in the frame, the spring will be bouncing up into the frame when you go over bumps...I would start off with some measurements from the rear hole in the frame to the front spring hanger mounting flange and post the measurement here and someone will verify it for you. I will bet the springs are just not the right ones.
Re: 1970 rr help [Re: RoadRunnerJD] #179772
01/02/09 02:53 PM
01/02/09 02:53 PM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
Were the rear frame rails on the car replaced? And if they were did you replace them with stock plymouth frame rails? I believe (am sure) there is a difference between dodge and plymouth frame rails as far as rear spring mounting locations. The front hanger is also different but that would move your spring location back, not forward if you were using front hangers from a dodge. So I wouldn't think that was the problem. But if you replaced the rear frame rails this may be something for you to look at. Just my Scott
70 Coronet RT 440+6
64 Dodge 330 - Future Hemi Clone
17 Challenger Hellcat - Green Go Driver
86 Buick T-Type Turbo V-6
Re: 1970 rr help [Re: RoadRunnerJD] #179773
01/02/09 10:44 PM
01/02/09 10:44 PM
USA
USA
the frame rails were replaced with a 49in set and a new cross member was installed the distance between the 2 are correct. we used a jig off a 70 rr.
Re: 1970 rr help [Re: hemipowered2] #179774
01/02/09 10:51 PM
01/02/09 10:51 PM
anlauto Offline
anlauto  Offline
What were the new rails out of?
Just throwing around ideas here but maybe the rear shackle tube is in different locations for different B Bodys???
Re: 1970 rr help [Re: anlauto] #179775
01/03/09 12:52 AM
01/03/09 12:52 AM
USA
USA
i bought them from auto body sp. they are direct replacements. all the parts came from them except the leaf springs there from spings-n-things.
