Re: Long trailers scraping....
[Re: Jeepmon]
#1797344
04/07/15 01:29 PM
04/07/15 01:29 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
Most use steel rollers at the back...Yours unfortunately does not and needs some.
[Re: Al_Alguire]
#1797350
04/07/15 01:36 PM
04/07/15 01:36 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Most use steel rollers at the back...Yours unfortunately does not and needs some. I knew I would end up with steel rollers.. but what hoping for a rubber/plastic type wheel.. What size wheels/rollers does everyone use? and does anyone have an opinion of those wheels that rotate.. like a shopping cart?
[Re: Jeepmon]
#1797860
04/07/15 09:26 PM
04/07/15 09:26 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
By using a longer steel roller on each side will work better than 2 steel wheels. Most of the time that trailer drags the rear is when you are turning into a drive. The narrow wheel will dig in and rip off, the longer roller will slide across and still turn. You also don't need them hanging down much at all, just enough to to save the back of the trailer.
[Re: Jeepmon]
#1798321
04/08/15 09:34 AM
04/08/15 09:34 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Most trailer manufacturers offer a "bogey wheel" option, you might contact the dealer for your particular brand and get a pair through them to save you some time.
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
