How much horsepower will 1/4 I.D fuel lines support? #1797058
04/06/15 12:09 AM
04/06/15 12:09 AM
western Il.
DRBNSB Offline OP
DRBNSB  Offline OP
western Il.
I am adding 150 shot of nitrous to my dart mild built 360 with 750cmf carb and air gap intake do I need to upgrade my fuel line from tank to fuel pump with 1/4 I'd fuel lines? How much horsepower will the lines suppor?
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: DRBNSB] #1797059
04/06/15 12:20 AM
04/06/15 12:20 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
My 18hp Craftsman has 1/4 inch line, if your going to upgrade go ahead and go -8 but a minimum 3/8.
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: Randy..] #1797060
04/06/15 12:23 AM
04/06/15 12:23 AM
western Il.
DRBNSB Offline OP
DRBNSB  Offline OP
western Il.
Thank you! That's exactly what I needed to know. Thanks for your help
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: DRBNSB] #1797061
04/06/15 12:35 AM
04/06/15 12:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Your 1/4" ID line is really called 5/16"... we use
the OD when talking or buying line/tubing
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: MR_P_BODY] #1797062
04/06/15 12:46 AM
04/06/15 12:46 AM
western Il.
DRBNSB Offline OP
DRBNSB  Offline OP
western Il.
I put calipers on it and it did measure .3125 5/16o.d. and .250 1/4 I.d. I wasn't sure what measurement was needed . Thanks
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: DRBNSB] #1797063
04/06/15 12:56 AM
04/06/15 12:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That was so you know what to ask for if you buy
tubing/line... its OD on that stuff(including exhaust
tubing)
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: MR_P_BODY] #1797064
04/06/15 01:04 AM
04/06/15 01:04 AM
western Il.
DRBNSB Offline OP
DRBNSB  Offline OP
western Il.
How much horsepower will 5/16 line support? Or is 3/8 the minimum? Thanks!
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: DRBNSB] #1797065
04/06/15 01:12 AM
04/06/15 01:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You would have to flow your line and find out... bends
in the tubing reduce flow... then once you find out
the flow you can figure .5PPH per HP.. that will give
you a decent idea
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: DRBNSB] #1797066
04/06/15 01:17 AM
04/06/15 01:17 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Chris,
I'm not telling anyone what to do, just relaying my personal experience. Last weekend my 3815lb 67 Belvedere went 119.5 Mph at Las Vegas. 440, 750 DP, and a 73 N20 jet in a big shot plate. I have stock 5/16 tank p/u, and stock 5/16 line. Carter mechanical pump and a T to carb, and solenoid.
I don't know why it clears the trap without nosing over, but it does. Somebody smarter than I can guess at the Horsepower.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: MoparBilly] #1797067
04/06/15 01:24 AM
04/06/15 01:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
he didn't mention the "hot" part and the DA was 5K or better for most of the weekend except for the early am runs. 2280 actual altitude.
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: J_BODY] #1797068
04/06/15 03:45 AM
04/06/15 03:45 AM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Is that your red thing next to Billy's Belvedere?
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: moparmanjames] #1797069
04/06/15 04:32 AM
04/06/15 04:32 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
"The Red Thing" is my son's 76 Fury Sport, James! That's pretty much the response from everyone in Vegas, no one knew what is was! It was his first outing, and Thermo-quad woes held him to pedestrian speeds. I'm letting him learn on his own terms, and he's as hard headed as his old man...
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: DRBNSB] #1797070
04/06/15 05:31 AM
04/06/15 05:31 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
fuel pump. I'Ve run into the 11's with 5/16 stuff. On a 125 shot. Old stock 440 deal.
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: MoparBilly] #1797071
04/06/15 12:15 PM
04/06/15 12:15 PM
Las Vegas NV
Las Vegas NV
Cool, no disrespect intended, I just saw that big car and thought it was a good opportunity to mess with Jay lol.
As for the topic, I've been mid 11's with 3/8" line to the mechanical pump and then the old 5/16" line up to the carb in a 3700# Roadrunner with 4.30 gears and a 29" tall tire.
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: moparmanjames] #1797072
04/06/15 12:37 PM
04/06/15 12:37 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
If you have a mild 360 and a good pump, 5/16 is plenty. Dwayne Porter (Porter Racing) had a roadrunner in the 10's with all motor and a 5/16 line.
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: DRBNSB] #1797073
04/06/15 12:42 PM
04/06/15 12:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The reason I say flow your system is that I have seen
some badly bent lines come out of the factory... bad
enough that the production car wouldnt run at WOT..
being that I worked in the fuel&exhaust lab I was
sent out to dealerships on many occasions to find
problems... this one car had a bad line on it but
it wasnt the only one I seen over the years... a
minor kink will really decrease the flow... and being
that the ID is already 1/4" it doesnt take much to
reduce the area
Re: How much horsepower will 1/4 I.D fuel lines support? [Re: Lee446] #1797074
04/06/15 12:47 PM
04/06/15 12:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I still have a 5/16th pickup in the tank on my car. Its been 11.18@120.5 in good air which works out to about 500HP. Its always had rock solid fuel pressure in the traps. Thats with a holley blue pump mounted in front of the passenger side spring hanger, it goes to -6 line from the pump forward.
It was meant to be temporary when I had nitrous on the car for a little while with a 360 even more clapped out than the one i have now. That was 14 years ago, the nitrous has been gone for 13 years lol.
68 Barracuda Formula S 340
