What's the factory spec for oil in 9.25" axles? #179653
12/31/08 01:22 PM
12/31/08 01:22 PM
Santa Cruz, California
Lefty Offline OP
Lefty  Offline OP
Anyone know what weight oil the FSM calls out for 9.25" Mopar axles? it's W I D E so I suspect truck, van or C barge origins.
Re: What's the factory spec for oil in 9.25" axles? [Re: Lefty] #179654
01/01/09 02:05 PM
01/01/09 02:05 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
80W90 will work fine. That's what I have in my '68 Fury (8.75). If it's a suregrip you'll need the additive also.
Re: What's the factory spec for oil in 9.25" axles? [Re: Lefty] #179655
01/01/09 04:10 PM
01/01/09 04:10 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
All the trucks I've had with 9.25's call for 85w140 and the newer ones call for synthetic, It runs about $13 a qt but I havent had any axle problems with it either.
Re: What's the factory spec for oil in 9.25" axles? [Re: MoparJoe] #179656
01/01/09 04:48 PM
01/01/09 04:48 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
80/90 for reg duty, 75/140 synthetic for towing and severe duty, This is from my owners manual for my 03 Dakota 9.25 limited slip 3.55. Had my rear end rebuilt at 30k under warranty started to howl bad, Then at 90k it started to growl and howl loudly again, this time i got the rebuild kit from Randys and replaced the carrier, pinion, bearings and races, the pinion seal, and crush sleeve, and axle bearings and seals. BTW i think the axle problems were do to the small vent barbed fitting being clogged i took a drill bit that was just a hair bigger than the original size and drilled it out both times the gear oil was milky because of the pluged vent
Re: What's the factory spec for oil in 9.25" axles? [Re: ademon] #179657
01/01/09 04:51 PM
01/01/09 04:51 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
BTW anyone with the newer 9.25 in their trucks take a few minutes to pull the hose off the axle vent and verify that it and the hose are clear, if it is cloged change the gear oil ASAP.
Re: What's the factory spec for oil in 9.25" axles? [Re: ademon] #179658
01/01/09 10:38 PM
01/01/09 10:38 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
80W90 IS for heavy and severe duty. Up until about 10 years ago that's what most heavy truck fleets were using. A lot of drivers I know had premature bearing failure using 75W140 syn oil in there diffs and transmissions.
Re: What's the factory spec for oil in 9.25" axles? [Re: Mopar1] #179659
01/02/09 12:17 AM
01/02/09 12:17 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Working at a dealer I would say that you mixed those two up. We saw a ton of rear gear failures in the 1500 trucks. Nothing tests a rear gear like and overzealous Californian towing his huge boat across the 120+ degree desert to get to the Colorado River. 75-140 worked way better. I know that in my 95 1500 when I would tow my enclosed car trailer in the summer I would get weapage around that lil rubber fill plug from the heat. Switched to 75/140 and it never happened again. ......as always, FWIW.
Re: What's the factory spec for oil in 9.25" axles? [Re: ademon] #179660
01/02/09 02:38 AM
01/02/09 02:38 AM
Lefty Offline OP
Lefty  Offline OP
Thank you!
