tire decal which is correct a body guys? #1796360
04/04/15 03:17 PM
04/04/15 03:17 PM
Social Republic of California
fc7vw9 Offline OP
fc7vw9  Offline OP
Putting some decals back on the car. I noticed the new one from ECS is different from the one that came with the paperwork that was with the car. I don't know if its off the car or its from another car. Car is a 70 340 4 speed dart swinger.
Thank you
Re: tire decal which is correct a body guys? [Re: fc7vw9] #1796361
04/04/15 03:58 PM
04/04/15 03:58 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thank you
So did you actually take that off the door post? Or was it loose in the paperwork with your car.
Need to confirm with other car from same plant. But maybe more than one sticker layout per that plant?
hmmm. Contact ECS.
Maybe a plane deal? What plant was your Swinger built. LA plant stuff doesn't get the attention in the hobby like the others do.
There's a green with flames 70 Swinger that usually comes out to Spring Fling. I could see that car still having the sticker.
Re: tire decal which is correct a body guys? [Re: autoxcuda] #1796362
04/04/15 04:02 PM
04/04/15 04:02 PM
fc7vw9 Offline OP
fc7vw9  Offline OP
Thank you
hmmm. Contact ECS.
It's a R Canadian built car. You a correct about the LA built cards though, in many ways they are entirely different in processes.
Maybe a plate deal? What plant was your Swinger built. LA plant stuff doesn't get the attention in the hobby like the others do.
Re: tire decal which is correct a body guys? [Re: fc7vw9] #1796363
04/04/15 04:23 PM
04/04/15 04:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have two 1970 Darts with original stickers, one from LA & one from Windsor. The labels are both different than shown above, but they are much closer to the one shown on the left & have different part numbers.
I do not know how many labels they used for the different tire options though, so if you have a broadcast sheet for your car look on Line 5, under LABELS. The last two digits of the part number on your original sticker will be printed there under TIRE.
Re: tire decal which is correct a body guys? [Re: Alaskan_TA] #1796364
04/04/15 04:45 PM
04/04/15 04:45 PM
fc7vw9 Offline OP
fc7vw9  Offline OP
Hello Mr Washington,
Unfortunately the car was gutted when I got it just dash frame and headliner. It did come with a window sticker and braking sheet maybe there is something on those.
Thank you
Re: tire decal which is correct a body guys? [Re: fc7vw9] #1796365
04/05/15 12:46 AM
04/05/15 12:46 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I just looked at a couple Windsor "R" '70 Dart sheets:
318 w/T12 tires 6.95x14 wsw = "92" tire label
/6 & 318 w/T64 tires D78x14 wsw = "52" tire label
and
340 w/T74 E70x14 white, T76 E70x14 RWL, T77 E70x14 black tires = "56" tire label
I'll "assume" the ECS #3402056 decal is accurate
Re: tire decal which is correct a body guys? [Re: 6bblgt] #1796366
04/05/15 01:39 AM
04/05/15 01:39 AM
fc7vw9 Offline OP
fc7vw9  Offline OP
and
Great assumption. Window sticker looks like T74......WSW though
Re: tire decal which is correct a body guys? [Re: fc7vw9] #1796367
04/05/15 01:55 AM
04/05/15 01:55 AM
fc7vw9 Offline OP
fc7vw9  Offline OP
Thank you for the info.
Ron
