Z Bar Gussets? #1796096
04/04/15 01:38 AM
04/04/15 01:38 AM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
Just curious as to whether anybody ever gussets there Z bar? I had a failure on mine today and was thinking about gusseting it when welding it back up. Is this a typical thing to do or am I going overkill?
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Z Bar Gussets? [Re: MadMopars] #1796097
04/04/15 01:48 AM
04/04/15 01:48 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The piece as shown could use some gussets or a wider/thicker bar with some gussets for added strength. From the pics the bar itself broke and it wasn't a weld issue. So a bigger bar and gussets would help.
Re: Z Bar Gussets? [Re: MadMopars] #1796098
04/04/15 02:34 AM
04/04/15 02:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure you put the rod on the correct side.. that
way it pushes straight and doesnt flex the arm
