383 Exhuast leak problem #179593
12/31/08 12:40 PM
12/31/08 12:40 PM
wisconsin
dodger1 Offline OP
dodger1  Offline OP
wisconsin
My Dad has a problem with his roadrunner burning out the gasket between the exhuast manifold and pipe flange, 3 times he,s replaced the gasket any ideas? Thanks
Re: 383 Exhuast leak problem [Re: dodger1] #179594
12/31/08 01:16 PM
12/31/08 01:16 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I would check to see if either of the two surfaces are warped. Expecially the pipe. Or the pipe isnt coming up to the manifold "true" meaning there is lateral tension on the pipe. This would cause the pipe surface and manifold surface to not mate up evenly.
Tried double gaskets?
Re: 383 Exhuast leak problem [Re: NTOLERANCE] #179595
12/31/08 03:21 PM
12/31/08 03:21 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
If you are using the stock exhaust manifolds, then no gasket is required. All Mopars with stock exhaust manifolds were put on with out gaskets and thus were only metal to metal. Check the surface facing on the manifolds and the heads and if need be a slight swipe of the surfaces will true them up. But get rid of the gaskets as they are not needed....
Re: 383 Exhuast leak problem [Re: CR8CRSHR] #179596
12/31/08 03:28 PM
12/31/08 03:28 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
He isn't talking about the gasket between the manifold and the head.
One thing I've noticed is that most muffler shops will make you an exhaust and will use a 3/8 bolt, which is a no-no because the hole in the manifold is something bigger (I think 7/16 but it's been awhile, I no longer run stock manifolds). The small bolt in a big hole allows everything to move around too much which causes gasket failure. But now that I typed all that, it will probably end up being something else.
Rich H.
Esse Quam Videri
Re: 383 Exhuast leak problem [Re: CR8CRSHR] #179597
12/31/08 03:31 PM
12/31/08 03:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
He said manifold to pipe flange not manifold to head... I fought a head pipe leak on my Challenger for years finally I bought a set of replacment flanges from Accurate LTD & rater then try cutting the original off & weld the new one on I sandwiched the new one between the original & the manifold then welded around the outside of both flanges...Haven't had a problem since...
Re: 383 Exhuast leak problem [Re: ZIPPY] #179598
12/31/08 03:40 PM
12/31/08 03:40 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Originally there was no gasket on the pipe, or head, side of the manifold. The gaskets are to take up slack ( So to speak) The mating surfaces have to be flat and even with each other. As the system heats up the seal should get tighter. If not the system will continue to leak as soon as the gasket gets burned out. I never had an luck stacking gaskets, ( 2 or more) but you just never know.
Re: 383 Exhuast leak problem [Re: dodger1] #179599
12/31/08 05:42 PM
12/31/08 05:42 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
One word,REMFLEX!!!.Best gaskets made. remflex.com
Re: 383 Exhuast leak problem [Re: 70RR383] #179600
12/31/08 05:46 PM
12/31/08 05:46 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
These motors do not need exhaust gaskets unless something is wrong.
Re: 383 Exhuast leak problem [Re: bboogieart] #179601
12/31/08 05:57 PM
12/31/08 05:57 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
Thats very easy for you to say.Have you ever had a exhaust leak???It drives you crazy.If you want to be that way and assemble and reassenble your manifolds and exhaust,go ahead,for me I put gaskets(remflex and forget about it.Also he is talking about the manifold to EXHAUST,not head.
Re: 383 Exhuast leak problem [Re: 70RR383] #179602
12/31/08 06:06 PM
12/31/08 06:06 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Thats why I now have headers
Re: 383 Exhuast leak problem [Re: 70RR383] #179603
12/31/08 06:14 PM
12/31/08 06:14 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I make sure all mating surfaces are flat and no leaks. No gaskets on either mating surfage as I stated befor.
Re: 383 Exhuast leak problem [Re: bboogieart] #179604
12/31/08 06:34 PM
12/31/08 06:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Really?
Re: 383 Exhuast leak problem [Re: 1_WILD_RT] #179605
12/31/08 06:49 PM
12/31/08 06:49 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Yep
just cuz someone makes something doesn't mean you need it. The factory might even have used them,(?)
but I never took one off a factory set up.
My cars are all older then that page (70&up).
I've been doing this since these cars were only 5 to 10 years old.
You my need them, all I am saying is I never have.
Get them on straight and they don't leak.
I have seen alot heat risers leak and folks thought it was at the pipe.
Re: 383 Exhuast leak problem [Re: bboogieart] #179606
12/31/08 07:02 PM
12/31/08 07:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: 383 Exhuast leak problem [Re: bboogieart] #179607
12/31/08 07:03 PM
12/31/08 07:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There has always been a gasket between the flat pipe and manifold. It is necessary and I have been working on these cars since the early 60s as a dealer tech.
Re: 383 Exhuast leak problem [Re: bboogieart] #179608
12/31/08 07:10 PM
12/31/08 07:10 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Yep
I am sure that we all are impressed by your ability to take used, mass-produced parts and align/true them up so as to not need a gasket, even in places that were originally assembled using a gasket.
The Original Poster, however, is not in your shoes, and is not helped by your claims.
Down to just a blue car now.
Re: 383 Exhuast leak problem [Re: 68HemiB] #179609
12/31/08 07:27 PM
12/31/08 07:27 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I don't want to anger you experts,
I am just saying what I know.
(Claims) Please.
Re: 383 Exhuast leak problem [Re: 1_WILD_RT] #179610
12/31/08 08:03 PM
12/31/08 08:03 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
According the the manuals & my experiance (I've worked on these cars since 72) 318 & 426 which both have cone type connections didn't use gaskets, big block does...
BTW I typed this earlier & got interupted so it's posted 45 minutes late...
Re: 383 Exhuast leak problem [Re: 1_WILD_RT] #179611
12/31/08 08:11 PM
12/31/08 08:11 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I had the same problem with them a couple of years ago,
I tried new gaskets from a couple of places, new correct size 7/16ths bolts, but the real problem was a mis alignment between the pipe and engine. The pipe hit the engine or torsion bar and would not allow the gasket to do it's job.
I had new head pipes made and installed at a local muffler shop and it was problem solved.
Re: 383 Exhuast leak problem [Re: sthemi] #179612
01/01/09 10:14 AM
01/01/09 10:14 AM
Southern Indiana
75RoadRunner Offline
Southern Indiana
Make sure you are using the correct size bolts, and the gaskets with the metal crush ring. If they are still blowing out, you have an alignment problem. Just my
