Re: Whats better grease-less or greaseable
[Re: moretoys]
#1795954
04/04/15 12:02 AM
04/04/15 12:02 AM
RapidRobert
As said hollow is weaker than solid but hollow works for most apps but 4wd etc I'd get a neapco or precision solid (probably others but those come to mind) & I'm wondering if there would be no issue with drilling/tapping the caps of a solid one for zerks or R&R it after so many months & pack the ends by hand. #1 problem with ujoints is move the front yoke back & forth in both planes & the rear ujoint in 1 plane after the ujoint install & it MUST be smooth & if it ain't then whack the ears (The 2 flat "connector" pieces on each end between shaft and the holes) till it is smooth (support the shaft off the ground so the ears take the whack). rare case you might need to R&R the new ujoint & repeat the install till it is smooth. I use a BFH as little as possible but just me I believe using one to drive in the caps as opposed to compressing them with a big vise is the best way
[Re: RapidRobert]
#1795955
04/04/15 12:45 AM
04/04/15 12:45 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
As said, the grease able kind are weaker due to the hollow body to allow the grease to flow
Lots of premium joints on the market with 'million mile warranty' that are not grease able.
**Photobucket sucks**
[Re: Lawn Monkey]
#1795956
04/04/15 02:18 AM
04/04/15 02:18 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
non grease-able as the premium
Proper lubrication is ALWAYS your friend...
[Re: RSNOMO]
#1795957
04/04/15 11:41 AM
04/04/15 11:41 AM
Posts: 7,664 IN
ahy
IN
That's my feeling also... however the better/best U joints available - strongest materials/best mettalurgy, best machining - seem to be non-greasable.
Non-greasable premium joints are all I have used for a few years on my hot rod and PU. So far so good.
[Re: ahy]
#1795958
04/04/15 03:08 PM
04/04/15 03:08 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
I've given up on greasables. No matter how often I grease them, they wear out faster than the sealed factory ones. I've done the axle outers on my '01 3 times now and went back to sealed. The greasables last about 40,000 if I'm lucky and the original factory ones went 70,000 miles.
I'm not sure if you are supposed to do it or not, but I have been adding just a little extra grease to the needle bearings on the sealed joints before I drive them in.
Pay extra, make sure you get Spicers.
Mo' Farts
Moderated by "tbagger".
[Re: ahy]
#1795959
04/04/15 04:01 PM
04/04/15 04:01 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I suppose it's debatable...
I've always looked at 'non-serviceable' as the cheap way out...
Anything on any of my cars, boats, etc., that has zerks gets the grease gun...
Often...
I've had much longer service life out of parts with a zerk...
The big spicers in the driveshaft of the B-body have been in there over 20 years...
They get fresh lube...
Often...
[Re: Lawn Monkey]
#1795961
04/04/15 05:52 PM
04/04/15 05:52 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I only buy spicer ujoints anymore, tried the neapco and other brands, spicers 1350's are almost what I exclusively use. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
