Ever see a lifter? #179551
12/31/08 12:25 PM
12/31/08 12:25 PM
IOWA
Duster75 Offline OP
Duster75  Offline OP
IOWA
this is what I found tearing down my plow truck because of a bent pushrod. guess engine was hungry Would cam bearing not installed properly cuase this? Its #1cyl. on a 360 exhaust lifter if it matters. Nate
Trucks/cars there all MOPARS 98 w2500 cummins24v5spd 85 w350 crew/short360 78 w150 shortfact.440 with upgrades 87 w150 soon to be new snowfighter 75 duster.... project since1999... never to be completed
Re: Ever see a lifter? [Re: Duster75] #179552
12/31/08 12:29 PM
12/31/08 12:29 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The bottom of lifter all dished out? Means cam most likely is also.
Re: Ever see a lifter? [Re: buildanother] #179553
12/31/08 12:49 PM
12/31/08 12:49 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Lifter stopped turning in the bore at one time or another. Cam is junk too, cam bearing probably had nothing to do with it unless it was so far out of the block it hit the lifter.
Re: Ever see a lifter? [Re: buildanother] #179554
12/31/08 12:51 PM
12/31/08 12:51 PM
IOWA
Duster75 Offline OP
Duster75  Offline OP
IOWA
Yeah, its wore/dished so bad oil is comming through the face on lifter the restof lifters look excellent no dishing/wear at all.going to try putting another lifter in it in hopes that the lifter was soft/ junk. its hard to see lob on cam b-cause #1 hole. don't have time to pull engine right now. Nate
Re: Ever see a lifter? [Re: Duster75] #179555
12/31/08 01:01 PM
12/31/08 01:01 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
lobe for that lifter is toast, too. and all that metal is now floating in the oiling system ready to get lodged in a bearing or piston skirt, ripe for scoring a cyl wall or crank.
the right thing to do is to tear the motor down, clean it out, replace the cam and lifters and put it back together.
hmm...did a valve stick causing the bent pushrod?
2017 Grand Cherokee Overland
Re: Ever see a lifter? [Re: patrick] #179556
12/31/08 01:39 PM
12/31/08 01:39 PM
IOWA
Duster75 Offline OP
Duster75  Offline OP
IOWA
Yeah, I checked lob and its gone... pulling front end off engine now to replace cam. As far as tear down........I know its best to tear her down but not in the books no time.Its in my plow truck = not making money = change cam drop the oil/ filter and hope for the best. Yes I think you are correct about pushrod.... nate
Re: Ever see a lifter? [Re: Duster75] #179557
12/31/08 03:28 PM
12/31/08 03:28 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
I've got several; the lobes they came off were pretty flat also.
New fangle paper weights , or .20 cents a pound scrap.
I know your misery.
Good luck.
Jim Burch
Re: Ever see a lifter? [Re: JBurch] #179558
12/31/08 04:28 PM
12/31/08 04:28 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I guess I'd look for a cheapie pull-out 318 or something to stick in there if you don't have the time to do it right.
Re: Ever see a lifter? [Re: Duster75] #179559
01/01/09 03:59 AM
01/01/09 03:59 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
When you tear the enging down you will see the metal from the cam got to all the bearings and oil pump
I thought the same as you to just put a new cam in, but when I checked the oil pump and bearings I ended up doing a minor rebuild. Had the block re-honed, then replaced the piston rings, all the bearings, the oil pump, cam and lifters.
Re: Ever see a lifter? [Re: Duster75] #179560
01/01/09 09:16 AM
01/01/09 09:16 AM
Montana
FuryUs Offline
FuryUs  Offline
Montana
You should tear it down and do a complete stroder rebuild with nothing but the best parts money can buy. Rebuild the plow setup and have the frame powdercoated while you're at it. Or...
Had that happen to me once. The lobe wasn't round yet, so I just tossed in a lifter and went on my way. It was a beater and lasted a while longer (until I got rid of the car, actually). A few quick oil changes might get most of the mess out of the engine if you're lucky.
Re: Ever see a lifter? [Re: FuryUs] #179561
01/01/09 10:09 AM
01/01/09 10:09 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Re: Ever see a lifter? [Re: Duster75] #179562
01/01/09 10:31 AM
01/01/09 10:31 AM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
it sure is time for a new cam and lifters.
Re: Ever see a lifter? [Re: 69Cuda340S] #179563
01/01/09 10:32 AM
01/01/09 10:32 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Don't forget the stainless steel bolts throughout, the air gap intake and the comp XE camshaft
Rich H.
Esse Quam Videri
Re: Ever see a lifter? [Re: FuryUs] #179564
01/01/09 07:31 PM
01/01/09 07:31 PM
IOWA
Duster75 Offline OP
Duster75  Offline OP
IOWA
thanks, I needed that....
Re: Ever see a lifter? [Re: ZIPPY] #179565
01/01/09 09:01 PM
01/01/09 09:01 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I was just posting how much dammage a wiped lobe did in my 360, and that it resulted in me doing a minor rebuild because I planned to keep the engine for awhile.
If your not going to keep the engine very long, sure just throw it back together and make sure your AAA is paid up.
