Re: a-body spindle ???
[Re: Stanton]
#1795445
04/03/15 02:57 PM
04/03/15 02:57 PM
Posts: 9,835 MI, usa
dvw
MI, usa
Reading this ad "73-76 a body spindles from a dart. large ball joint disc brake spindles ..." and I'm wondering about the "large ball joint" statement.
Can you tell the difference by just looking at them? Which ball joint would a '69 b-body have used, large or small?
The large ball joint spindles are for disc brake. They will fit A,B, and E body. The corresponding large upper ball joint disc only upper control arm is required if being used on an A-body. B and E body upper arms are all large ball joint regardless of brake type. Doug
[Re: DoctorDiff]
#1795448
04/03/15 04:38 PM
04/03/15 04:38 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
All '73 and newer A-bodies (disc and drum) used the "large" B and E body upper and lower ball joint.
That's true except if you ever run across a few odd ball, stripped down, 73 A body, 6 cylinder, 9 inch, DRUM Brake cars,that were produced that way.
They then were Small ball joint.
But those type of cars are few, and far between, in this day and age.
RF-4C Phantom 69-370 Zweibrucken, Germany
