Re: How to remove a U-joint
[Re: Sir Valiant]
#1795423
04/03/15 11:23 AM
04/03/15 11:23 AM
Posts: 1,841 South Bend
John Brown
South Bend
Unless it has that plastic injection thing like GM loved to use.....
[Re: Finoke]
#1795425
04/03/15 01:12 PM
04/03/15 01:12 PM
RapidRobert
clamp the shaft moderately secure in the vice will a towel to protect it with pretty much just the end weld/ears sticking out past the vice. clips removed. drive one cap in till it pushes the opposite cap out enough so you can grab it with vice grips & twist it out/off. then drive the greasy shank of the ujoint back in the other way till you can grab/remove the other cap. Spacial awareness/frequent checking so you ain't banging/nicking anything improper
[Re: cogen80]
#1795427
04/04/15 02:28 AM
04/04/15 02:28 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Just did that a few hours ago with a Harbor Freight 12-ton press. On the bottom side I used a 3/4 drive socket the same size as the U joint cup. A short (about 8") lever on the press hydraulic jack wasn't getting the job done. Put a longer lever on the jack, and it worked great.
For a bit more than $100 with coupon, this press is an excellent buy for many jobs like this and takes up minimal floor space.
[Re: kentj340]
#1795428
04/05/15 12:06 AM
04/05/15 12:06 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Ask your powder coater about leaving the universal joints or at least the caps in for the coating process. This will leave the inside surface the caps sit in free of coating.
