NEED expert 98 5.9 magnum tech
#1795327
04/03/15 12:49 AM
04/03/15 12:49 AM
Posts: 854 PHOENIX
8T2TOP
PHOENIX
I have the dreaded idle problem that you see all over the web CAN NOT find the answer. NO CEL iac removed cleaned it happens cold open loop when op temp smooths out all those web topics replace various items with no results I want my truck back and fixed! so please ideas? new exhaust manifolds back 170k recent tune
Re: NEED expert 98 5.9 magnum tech
[Re: 8T2TOP]
#1795328
04/03/15 02:19 AM
04/03/15 02:19 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
What problem is it having? Too fast? Too slow? Rough?
[Re: HotRodDave]
#1795329
04/03/15 02:33 AM
04/03/15 02:33 AM
Posts: 854 PHOENIX
8T2TOP
PHOENIX
https://youtu.be/mfgmGZ3qR0INOT MY TRUCK same condition but i have seen and read others that replaced iac tps map with no results 1000's of topics/post no real answer..
[Re: 8T2TOP]
#1795331
04/03/15 11:09 AM
04/03/15 11:09 AM
Posts: 20,646 in a cattle trailer down by th...
Guitar Jones
Hard to tell anything from that video but things to check are of course the pan on the bottom of the intake manifold. The other thing I've found is the wires for the coolant temp sensor behind the thermostat housing will get dry, brittle and flake the insulation off and the wires will short together. When that happens the PCM will see the coolant temp as -40* so it richens the fuel mixture a bunch. This and also a thermostat that is stuck partially open will run the adaptive fuel mixture way rich. So even after you fix these problems you need to clear the adaptive memory by removing the positive battery cable from the battery. Touch the removed cable to the battery negative terminal and hold it for 30 seconds. This does a cap discharge and the learning process will start over so it may not idle well at first. Cycle the engine on and off a few times then drive it for awhile so it can relearn.
[Re: Guitar Jones]
#1795332
04/03/15 09:39 PM
04/03/15 09:39 PM
Posts: 1,728 ST clair shores MI
moretoys
ST clair shores MI
you are looking for a miracle solution, it's not that simple. proper diagnosing needs to be done.
did you clean the throttle body also? need to get the crude out of the throttle body butterfly. air needs to pass through them cleanly.
need a scan tool to read the air temp sensor (in intake plenum), MAP sensor, injector time and the coolant temp sensor. sensor can be within it's parameters and NOT set a code. could be reading wrong, computer only knows extreme high or low or open or closed circuit for the codes., A scan tool will also read the oxygen sensors, and see what they are doing. again they can be within it's parameters but read wrong for what i is actually doing or needed and NOT set a code.
I have seen the ground wire corroded and give goofy readings to the 02 sensors. it also operates the heater circuit of the sensor ( ground wire is at the driver front cylinder head area)
weak ignition system will show up more during cold / warm up than when at operating temperature. are the cap,wires, spark plugs good? ignition coils go bad all the time.if you have a special spark plug in it, then change them to the normal champion. these hate those bosch platinum especially.
bad intake plenum can be checked by pulling the pcv valve and breather hose out of the valve cover, cover 1 hole and check for vacuum at the other hole. if vacuum present, then plenum is sucking from underneath. any other vacuum leak can cause problems. you will usually see that at the MAP sensor reading.
low fuel pressure can cause problems, low pressure will be more troublesome cold than at operating temperature. (eg) if spec is 37-45 and it is at 30, you will have cold running problems. but probably run ok, maybe a touch low on power. if a fuel injector isn't spraying correctly, it will cause more problems cold than warm.
1 other thing and I don't remember what years have and not have.(brain fart) is the egr valve can be stuck slightly open. Thinking you do not have 1, but just putting it out there, since some years do and some don't. (causes and internal vacuum leak)
you say you here a loud sucking noise, my first thought is fuel issue somehow, low pressure or computer is closing / opening injector because of some false reading. alot of these sensors can be monitored with a volt/ohm meter, but you need there specific chart as the reading change with temperature, they are not all the same.
make sure the connectors do NOT any corrosion in them, this causes resistance in the reading and the sensor output signal to be wrong.
[Re: 8T2TOP]
#1795335
04/04/15 09:58 AM
04/04/15 09:58 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Above advice is reasonable.
1998 Magnum V8s have computer systems that are OBD-II Friends that had post 1996 OBD-II systems seem to be very sensitive to battery health. Batteries that were old and still able to start the truck would cause very "squirrelly" problems including an intermittent rough idle.
While troubleshooting make sure you have a good battery and clean ground connections.
On my 1995 OBD-I system the most challenging intermittent problems occurred around 180,000 miles.
I had come and then go warmed up rough idle at first. Then the truck would suddenly die on the highway, refuse to restart for 10 to 30 minutes, then start back and run fine for hours before having the same problems again.
In the end this turned out to be a plugged up "sock filter" at the bottom of the in tank fuel pump/pressure regulator/ double fuel filter assembly.
The lowermost sock filter was causing the fuel pump suction to "cavitate" when the fuel got hot, which causes very sudden fuel flow loss,
Fuel pump, pressure regulator, and high pressure fuel filter were still good at 180,000 miles, but the sock filter designed to protect the pump from wear was causing odd and intermittent behavior.
[Re: moretoys]
#1795336
04/04/15 02:07 PM
04/04/15 02:07 PM
HotRodDave
Kalispell Mt.
If the o2 sensor is suspect (and it is) try un plugging it. You will need to wipe the computer memory either with a scanner or un hook the battery for 10 minutes or so. Leave the sensor un plugged and drive it. I have seen them cause it, that reminds me, my wife's van has the sensor unplugged for that very reason and I need to pick up a sensor.
[Re: HotRodDave]
#1805410
04/17/15 02:21 AM
04/17/15 02:21 AM
Posts: 854 PHOENIX
8T2TOP
PHOENIX
Thanks for the replies you are all awesome! have not been able to test o2 or do anything,am in severe pain no egr mopar cap rotor wires o.e. champions throttle body spotless plenum gasket ok new battery no corrosion anywhere o2 does not operate in open loop poor can not afford a scanner or a place that has one unless someone near kingsport ,tn can come help with one i belive it to be something electrical because when cold it does it shut off still cold starts fine then minute or two back to doing it, if it was mechanical or vacuum leak would always be present not stop and do it on restart. just dont understand when i try to drive to store mile or so it is popping thru tb how can that not set CEL? sorry that i am wanting a miracle with no money are you sure touching battery terms together will not fry the PCM? once again everone here THANK YOU!! http://www.gofundme.com/p523e8
[Re: 8T2TOP]
#1805460
04/17/15 09:31 AM
04/17/15 09:31 AM
Guitar Jones
You carefully remove the positive cable end from the battery. Touch the positive cable end (NOT the battery terminal) to the ground. The battery is taken out of the system at this point. If it makes you feel better remove the battery completely, touch the two cable ends together, this will drain the capacitors in the PCM and start the learning process over. We do it all the time.
[Re: 8T2TOP]
#1806081
04/18/15 07:02 AM
04/18/15 07:02 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
You have no tools to properly diagnose the issue and you won't take it to a mechanic with the correct tools and training to diagnose your issue. You will be simply throwing parts at the truck praying that the next part you install will magically fix the problem. All I can tell you is good luck, say some prayers and maybe sacrifice a chicken or two.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
