Good balancer ?????....UPDATE....MUSCLE MOTORS.. #1795257
04/02/15 10:52 PM
04/02/15 10:52 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Is this a good quality balancer? I think its a Powerforce, or Powerbrand. Shows part #15961 & # PB 1112SS. Is this a stock type replacement balancer? Let me know your opinions then I'll tell ya what engine it's on.
..UPDATE.... This was put on a 622 with PSO heads and a 4.75 Callies crank that cost me over 20k built by ..MUSCLE MOTORS....Ive had other issues with this engine and have gotten ZERO support from them after they got my final payment.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Good balancer or elcheapo.... [Re: steve660] #1795258
04/02/15 10:53 PM
04/02/15 10:53 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
#2
Re: Good balancer or elcheapo.... [Re: steve660] #1795259
04/02/15 10:54 PM
04/02/15 10:54 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
#3
Re: Good balancer or elcheapo.... [Re: steve660] #1795260
04/02/15 10:55 PM
04/02/15 10:55 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
#4
Re: Good balancer or elcheapo.... [Re: steve660] #1795261
04/02/15 10:56 PM
04/02/15 10:56 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
#5
Re: Good balancer or elcheapo.... [Re: steve660] #1795262
04/02/15 10:57 PM
04/02/15 10:57 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
#6
Re: Good balancer or elcheapo.... [Re: steve660] #1795263
04/02/15 10:58 PM
04/02/15 10:58 PM
Q
Quicktree Offline
Quicktree  Offline
Q
do you even have to ask? chinese
Re: Good balancer or elcheapo.... [Re: steve660] #1795264
04/02/15 11:06 PM
04/02/15 11:06 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
When I buy parts for my race car , I buy parts that I see on many other race cars.........or make them if I have to.
Street car ? My criteria aren't quite so strict , but I still am not afraid to pay for quality.
This one is an el cheapo.........it might be fine for your application.
Or it might not.
Re: Good balancer or elcheapo.... [Re: Quicktree] #1795265
04/02/15 11:20 PM
04/02/15 11:20 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Just wanted other opinions.. Engine builder told me they run this balancer on street engines because, and I quote.."They maintain good pulley alignment for street applications." That's BS....I have ran Fluidamper and have had no problem with pulley alignment. Stay tuned for more info on what the engine is.......still wanting more opinions.
Re: Good balancer or elcheapo.... [Re: steve660] #1795266
04/03/15 12:03 AM
04/03/15 12:03 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
PowerBond is the brand that the late Dan Costello suggested as a good budget SFI damper. Jegs offers them under their own name, too.
Professional Products' Powerforce dampers seem to be another story and would NOT be on my list of acceptable dampers for any application.
Re: Good balancer or elcheapo.... [Re: BradH] #1795267
04/03/15 02:28 AM
04/03/15 02:28 AM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
scribe the timing mark down the front in case it moves for an oh sh*t indicator ....
SFI 25.5 depends,no leak,even at 213 mph....
Re: Good balancer or elcheapo.... [Re: steve660] #1795268
04/03/15 02:57 AM
04/03/15 02:57 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
that looks like the same one that was on my 440 short block i bought. mine has been going for over 4 years now and i have not had any problems with it.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Good balancer or elcheapo.... [Re: mopar65] #1795269
04/03/15 03:04 AM
04/03/15 03:04 AM
mopar65 Offline
mopar65  Offline
sorry for got to add the only thing i don't like about it is i think the balance r is to thin to use with a stock timing chain cover. by that i mean the timing marks numbers like 32/34/36 etc they sit under the timing cover tab. I think they should of engraved the timing numbers longer.
Re: Good balancer or elcheapo.... [Re: dakotawilly] #1795270
04/03/15 04:52 AM
04/03/15 04:52 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Not enough to do so, i have seen cheap balancers turn into fragmentationgrenades without even trying to slip,small and big chunks real dangerous will never buy a cheap balancer and hope its ok street or racecar does not mather they can turn into danger at less than 6000rpm and have seen them take a fuelpump outlet with them..
Re: Good balancer or elcheapo.... [Re: 1Fast340] #1795271
04/03/15 06:59 AM
04/03/15 06:59 AM
Australia
L4staero Offline
L4staero  Offline
Australia
I believe they are made down here in OZ by powerbond....... hence the PB in the part number, sold also in usa under pioneer name....ive used them before no worries and lots of 9-10 sec cars here running power bond balancers
Re: Good balancer or elcheapo.... [Re: steve660] #1795272
04/03/15 08:34 AM
04/03/15 08:34 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I like the ATI super damper for racing. I have a 440source damper on my street car.
Re: Good balancer or elcheapo.... [Re: steve660] #1795273
04/03/15 10:30 AM
04/03/15 10:30 AM
an8sec70cuda Offline
I'm pretty sure I know exactly what caliber of motor this balancer is on and there's no way I'd run it. Get an ATI.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Good balancer or elcheapo.... [Re: an8sec70cuda] #1795274
04/03/15 10:45 AM
04/03/15 10:45 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
x2 on any race motor....
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Good balancer or elcheapo.... [Re: L4staero] #1795275
04/03/15 11:13 AM
04/03/15 11:13 AM
BradH Offline
BradH  Offline
Yep; these are Pioneer's SFI dampers, too.
They're not junk, but they're no ATI either.
Re: Good balancer or elcheapo.... [Re: BradH] #1795276
04/03/15 12:32 PM
04/03/15 12:32 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Little more info........The engine builder put this balancer on a 4.75 stroke Callies crank. Dyno'd at 1000hp. I am not comfortable using it....going either Fluidamper or ATI. Wait....I was "TOLD" it was a Callies crank..... <img src="/ubbthreads/images/graemlins/1343795-scratchchin.gif" alt="" />
