727/518 Transmission Clearances and Line Pressure. #1795169
04/02/15 08:25 PM
04/02/15 08:25 PM
Wi
Scat Offline OP
Scat  Offline OP
Wi
Im putting my trucks transmission back together and have the Trans go TFOD-3 shift kit currently in it. Im trying to get ahead of burning everything up. Heavy truck 5000lbs with 1200-1300hp and tons of torque. I have talked to a few people and all i know is i need at least 225psi for fixed line pressure. How have peopled locked the TV on the valve body??? What is a good rule of thumb to go on for the direct and forward clutch packs? Input in and out clearance??? 7 clutch direct and 5 clutch forward packs currently.
73 Duster 340 a518 6pack
Re: 727/518 Transmission Clearances and Line Pressure. [Re: Scat] #1795170
04/02/15 08:33 PM
04/02/15 08:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can wire the TP arm back to lock it at max.. I'll
look around for my 518 book and see what the clearances
are... sure hope you dont use the LU or OD with that
kind of power... you might want to use a 618 and
the valve body from a 518
Re: 727/518 Transmission Clearances and Line Pressure. [Re: MR_P_BODY] #1795171
04/02/15 09:23 PM
04/02/15 09:23 PM
Wi
Scat Offline OP
Scat  Offline OP
Wi
Its a diesel transmission behind my cummins. Last time it was ran was behind a 650hp motor and now well i stepped up my game a bit lol. Billet everything and even an Arment 100 input aswell.
Re: 727/518 Transmission Clearances and Line Pressure. [Re: Scat] #1795172
04/03/15 01:04 AM
04/03/15 01:04 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
.015" per disc.
Doug
Re: 727/518 Transmission Clearances and Line Pressure. [Re: Scat] #1795173
04/03/15 11:16 PM
04/03/15 11:16 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
Is this a 727 or 518? I am assuming you are driving it on the street.
225# fixed line? Plan on replacing the direct drum or its piston as they will break.
It will not shift properly at that line without extensive moifications, so plan on setting it up for full man shifts.
The pump and any iron rings will soon be destroyed.
Converter? Hmmmm...
Time to talk to experts in the hi-per field with chipped up diesels. I would contact Goerends. http://www.goerend.com/ They are the experts in diesel Torqueflites.
" The last official act of any goverment, is to loot the treasury" George Washington
