New 3:55 gears always howl. True or False? #1795037
04/02/15 04:34 PM
04/02/15 04:34 PM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
I had a very respected Mopar guy who runs a tranny and rear end shop rebuild my 489 pig. He advised against the 3:55 gear because he said they don't cut the teeth the same way as they used to and they ALL howl now regardless of brand. It just affects the 3:55 gear set for some reason. He also said that if I was determined to go with the 3:55, the best thing to do was find NOS factory gears.
Anyway I went ahead and they do howl around freeway speeds. I thought I could live with it but the gear reminds me its there over and over again. So now I'm thinking of 3:73...
Anyone else heard of this?
'71 GTX N96 auto 3:55 '74 Challenger 440+6 4spd 4:10 '71 Duster 340 auto 4:10
Re: New 3:55 gears always howl. True or False? [Re: NOrrTH] #1795038
04/02/15 04:50 PM
04/02/15 04:50 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
That's BS.
The gears aren't set up properly.
He's blowing smoke at you.
Need to find someone else that knows what they're doing, and talking about.
When i first started out as an auto mechanic, i worked at a shop doing differentials, here in my city.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: New 3:55 gears always howl. True or False? [Re: hemi71x] #1795039
04/02/15 04:59 PM
04/02/15 04:59 PM
an8sec70cuda Offline
That's BS.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: New 3:55 gears always howl. True or False? [Re: NOrrTH] #1795040
04/02/15 05:07 PM
04/02/15 05:07 PM
AndyF Offline
AndyF  Offline
That just doesn't make sense. Give DoctorDiff a call and see what he can do for you. He is in Montana which isn't a huge distance from B.C.
Re: New 3:55 gears always howl. True or False? [Re: AndyF] #1795041
04/02/15 05:43 PM
04/02/15 05:43 PM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
Thanks guys
Re: New 3:55 gears always howl. True or False? [Re: NOrrTH] #1795042
04/03/15 12:31 AM
04/03/15 12:31 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
I have a 3.55 gear set in my Challenger, every part is new and was bought from Doctor Diff and doe`s not howl at all.
I have 5000 miles on the setup.
Re: New 3:55 gears always howl. True or False? [Re: NOrrTH] #1795043
04/03/15 12:59 AM
04/03/15 12:59 AM
I submit that they were a set that was setup wrong & howled for a prior owner & he is (now) attempting to pawn them off on you to cut his loss(es). EDIT Competent and crooked are two different attributes & they ain't mutually exclusive. The tip off (to me) on this deal was him blaming the numerical ratio choice as being the problem
Re: New 3:55 gears always howl. True or False? [Re: NOrrTH] #1795044
04/03/15 01:03 AM
04/03/15 01:03 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Good grief
I want my fair share
Re: New 3:55 gears always howl. True or False? [Re: hemi71x] #1795045
04/03/15 01:09 AM
04/03/15 01:09 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
That's BS.
Need to find someone else that knows what they're doing, and talking about..
Re: New 3:55 gears always howl. True or False? [Re: SomeCarGuy] #1795046
04/03/15 01:11 AM
04/03/15 01:11 AM
Kirkland, Washington
Pacnorthcuda Offline
The quietest 3.55 aftermarket is the U.S./Strange. I am currently running a set, and it's NOT noisy. In fact, it's quieter than 2 of the 3 factory 3.55's I've ran.
Re: New 3:55 gears always howl. True or False? [Re: Pacnorthcuda] #1795047
04/03/15 09:25 AM
04/03/15 09:25 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I bought a brand new 3rd member from Mancini a few years back. I'm not sure who's 3.55 gears they used in assembling it but it's quiet as can be!
Re: New 3:55 gears always howl. True or False? [Re: GY3] #1795048
04/03/15 10:38 AM
04/03/15 10:38 AM
New York
rarefish Offline
rarefish  Offline
New York
I bought a used third member with 3.55 gears years ago and when I installed them they howl. I put up with it for a long time. Then about 5 years ago I bought a new OEM 3.55 ring and pinion from Mancini's. I had a one man shop that does only rear ends, set them up with all new bearings. When I installed them they also howl like the last set just at a different rpm range. The guy told me that the gear pattern looked great when he set them up. I have had people tell me the howl might be coming from the axle bearings, but I don't believe that.
Re: New 3:55 gears always howl. True or False? [Re: NOrrTH] #1795049
04/03/15 01:36 PM
04/03/15 01:36 PM
North Texas
TheTieWrapKid Offline
North Texas
FALSE !!
Re: New 3:55 gears always howl. True or False? [Re: TheTieWrapKid] #1795050
04/03/15 01:47 PM
04/03/15 01:47 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Any gear can be noisey if there's a problem. Problems are not always with the gears themselves, or even from the chuck. But - if there are not other issues, and they are broken in proerly, no gear ratio in and of itself will be noisey.
Re: New 3:55 gears always howl. True or False? [Re: moper] #1795051
04/03/15 02:30 PM
04/03/15 02:30 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
This is what I was thinking. My friend who built my 489 case 3.55 gears is very picky about how it's set up. Even when I was putting my 8 3/4 together he didn't want me to consult anyone but him. He was extra particular about how the gears were broke in, especially with a 489 case that has a crush sleeve. IIRC he states 20 minutes of light street driving and 2 hours of rest to cool down for about 3 cycles, always use an 85w gear oil or higher, and no burnouts/towing for the first 500 miles.
Re: New 3:55 gears always howl. True or False? [Re: AndyF] #1795052
04/03/15 06:36 PM
04/03/15 06:36 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I have often heard that 3:90's are a problem. What is the collective wisdom on this allegation?
Re: New 3:55 gears always howl. True or False? [Re: Sxrxrnr] #1795053
04/03/15 06:41 PM
04/03/15 06:41 PM
md
mopars4ever Offline
mopars4ever  Offline
md
True or False I don`t know but I do know the 3.55 gears I had many moons ago did howl.
Re: New 3:55 gears always howl. True or False? [Re: mopars4ever] #1795054
04/03/15 07:50 PM
04/03/15 07:50 PM
Nanaimo, BC
N
NOrrTH Offline OP
NOrrTH  Offline OP
N
Nanaimo, BC
I broke in my "new" set very easy.
I don't want to mention any names, but this guy is very wealthy, has lived mopars since he was a kid, owns about 30 of them now, some of which are worth hundreds of thousands, drag races and is a bit of a Mopar celebrity in these parts...and he runs a transmission shop which has been doing rear ends for decades.
My point is, he's not some Craigslist back yard mechanic, hack.
Now I'm really scratching my head
Re: New 3:55 gears always howl. True or False? [Re: NOrrTH] #1795055
04/03/15 09:13 PM
04/03/15 09:13 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
There are particular gear sets than will be noisy, no matter the set-up. But that is more brand or batch specific, than ratio specific.
Master, again and still
Re: New 3:55 gears always howl. True or False? [Re: an8sec70cuda] #1795056
04/03/15 11:48 PM
04/03/15 11:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
That's BS.
The other common Fallacy is that the lower you go the more they will whine, BULLS$heet I say. I have run gear sets as low as 5:13's in a street car that were quiet as a church mouse. I've run 3:91's, 4:10's, 4:30's, 4:56's, 4:88's and 5:13's. ALL QUIET noise wise WHEN SET UP PROPERLY. IF one is talking about special RACE only sets that could be a different story.
