Re: MP 3.79" cranks
[Re: justinp61]
#1794570
04/02/15 01:37 PM
04/02/15 01:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I copied this from another site so I don't know how accurate it is.
HD cast cranks
P5007256 4.00" stroke, 318/340 mains P5007257 3.58" stroke, 318/340 mains
Forged cranks
P4120312 3.45" stroke - 6-bolt flange - 1053 steel - 318/340 main P4120504 3.31" stroke - 8-bolt flange - 1053 steel - 318/340 main P4529709 3.38" stroke - 6-bolt flange - 1053 steel - 318/340 main P4529710 3.51" stroke - 6-bolt flange - 1053 steel - 318/340 main P4529711 3.55" stroke - 6-bolt flange - 1053 steel - 318/340 main P4529712 3.60" stroke - 6-bolt flange - 1053 steel - 318/340 main P4529713 3.65" stroke - 6-bolt flange - 1053 steel - 318/340 main P4529714 3.71" stroke - 6-bolt flange - 1053 steel - 318/340 main P4529715 3.79" stroke - 6-bolt flange - 1053 steel - 318/340 main P5007252 4.00" stroke - 6-bolt flange - 4340 steel - 318/340 main P5007253 3.58" stroke - 6-bolt flange - 4340 steel - 318/340 main
4340 steel billet cranks
P4876013 3.55" stroke - 6-bolt flange - 318/340 main P4876014 3.50" stroke - 6-bolt flange - 318/340 main P4876015 3.48" stroke - 6-bolt flange - 318/340 main P4876016 3.45" stroke - 6-bolt flange - 318/340 main P4876065 3.35" stroke - 6-bolt flange - 318/340 main P4876066 3.385" stroke - 6-bolt flange - 318/340 main P4876067 3.42" stroke - 6-bolt flange - 318/340 main P4876788 3.79" stroke - 8-bolt flange - 318/340 main P4529802 3.50" stroke - 8-bolt flange - 318/340 main
This looks like it was cut and pasted from the MP book... but its one of the newer books because of some of the PN... 5007 is newer stuff... but this also shows the 3.79 billet as a 8 bolt.. both of mine are 6 bolt... MAYBE they changed over to a 8 bolt in the last few years... let me go look at some of my MP books and see whats in them
Re: MP 3.79" cranks
[Re: Blucuda413]
#1794574
04/02/15 08:23 PM
04/02/15 08:23 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Mike, it does show fordged 8 bolt in either my 1995 or 2001. Can't remember which.
Does it show them as 1053 or 4340?
Re: MP 3.79" cranks
[Re: Blucuda413]
#1794575
04/02/15 08:24 PM
04/02/15 08:24 PM
MR_P_BODY
In my 2001 book it shows a 3.79 forged 6 bolt 1053 material but not a 8 bolt.. they did/do offer a billet 3.79 with a 8 bolt flange( this data is from my 2001 book)
Re: MP 3.79" cranks
[Re: sbdemon]
#1794579
04/03/15 12:50 PM
04/03/15 12:50 PM
MR_P_BODY
Hi
The P4529715 crankshaft is, surface hardened, forged 1053 steel, radiused fillets main and rod, eight-bolt flange, 318 mains, according to the 97 and 98 MP catalogs. I have one in my engine.(pic is from MP catalog).
sbdemon
That same PN in my 2001 book shows it to be a 3.79 6 bolt 1053 crank... so I gather that PN will/can be either a 6 or 8 bolt 3.79 1053 crank
Re: MP 3.79" cranks
[Re: 340_Dart]
#1794582
04/03/15 01:16 PM
04/03/15 01:16 PM
MR_P_BODY
I'm following along to hopefully learn something here. Is the 1053 a steel weak compared to 4340? Whats a used crank of either steel worth? I'd like to eventually build a 3.79" motor one day.
The billet cranks are made from 4340.. that might tell you
Re: MP 3.79" cranks
[Re: justinp61]
#1794583
04/03/15 01:26 PM
04/03/15 01:26 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Now I need to decide if I want to run the 3.79" crank or buy a 4.00" for this build. Like all of mine, it'll be a pump 93 deal, R1 block, 4.09" bore, ported Indy 360-1s, most likely T&D rockers, Indy intake and a yet to be decided solid roller.
I faced the same dilemma a few years ago, decided to skip the 4.00, and go to the 4.125 to justify not using the 3.79. It was the right decision!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
Re: MP 3.79" cranks
[Re: 340_Dart]
#1794585
04/03/15 01:32 PM
04/03/15 01:32 PM
MoparBilly
Phoenix, AZ
My 3.79 has plenty of runs on it, but has never been hurt, and is standard, so a 10/10 would certainly make it perfect, but a polish would probably do. I listed it in the parts section a while back for 350$ and got zero interest, so I don't know what it might actually "Be worth" or sell for.
Re: MP 3.79" cranks
[Re: MR_P_BODY]
#1794586
04/03/15 03:39 PM
04/03/15 03:39 PM
Posts: 19 Sweden
sbdemon
Sweden
Yes Mr P Mopar + part numbers + casting numbers = one of the greatest and most fascinating mysteries of our time. sbdemon
Re: MP 3.79" cranks
[Re: sbdemon]
#1794587
04/04/15 08:30 PM
04/04/15 08:30 PM
Posts: 11,542 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have a NIB P4529715 dated 1992. I have thought about selling it, but if it will only bring a few hundred, I'll keep it for possible future use. As I understand, 1053 is the material used for OE steel 340 cranks and others. Not sure of the limitations of these, but I've spun stock crank 340s pretty high with no issues.
Re: MP 3.79" cranks
[Re: MoparBilly]
#1794589
04/04/15 11:33 PM
04/04/15 11:33 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
great day in the morning...... Big Block Mopar Billy is joining in on a small block conversation. Will the sun come up tomorrow??
carry on.....
