Banana Groove orientation small block #1794342
04/01/15 06:08 PM
04/01/15 06:08 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
when using Crane Iron Adjustable Rocker Arms, wouldn't I need the Banana grooves on the shaft faceing Up, Not down like stamped rocker set-ups? with them down, the small oiling hole on the rocker arm will never be allighned with any oiling groove.
Re: Banana Groove orientation small block [Re: titan] #1794343
04/01/15 06:58 PM
04/01/15 06:58 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
grooves facing up
Re: Banana Groove orientation small block [Re: titan] #1794344
04/01/15 07:00 PM
04/01/15 07:00 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
grooves down
Re: Banana Groove orientation small block [Re: titan] #1794345
04/01/15 07:13 PM
04/01/15 07:13 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Grooves face down & toward the spring.
Re: Banana Groove orientation small block [Re: titan] #1794346
04/01/15 07:17 PM
04/01/15 07:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
grooves facing up
You can see the grooves were on the LOAD side(load
side is the down side... everything pushes up).. so
put them down so the oil can spread out on the load side
Re: Banana Groove orientation small block [Re: rickraw] #1794347
04/01/15 07:19 PM
04/01/15 07:19 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
so little oil hole on top of rocker arm does nothing? because all it will ever see is solid shaft.
Re: Banana Groove orientation small block [Re: titan] #1794348
04/01/15 07:55 PM
04/01/15 07:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It lets the oil out to the groove... you pick up
oil to the shaft at 2 and 4 stanchions .. there
is a direction of the shafts also... look for the notch
at the end
Re: Banana Groove orientation small block [Re: MR_P_BODY] #1794349
04/01/15 09:07 PM
04/01/15 09:07 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
I am refering to the hole on the rocker arm. above the fulcrum, that you see in the first photo. I assume oil should come out of this hole , but with the grooves on shaft facing down, that hole is only riding on the shaft never coming near any of the grooves to feed it oil?
Re: Banana Groove orientation small block [Re: titan] #1794350
04/01/15 09:18 PM
04/01/15 09:18 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Face the grooves down. The oil will get there. If you put the grooves up you will most likely gauld your rockers.
Re: Banana Groove orientation small block [Re: titan] #1794351
04/01/15 11:06 PM
04/01/15 11:06 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
...so a sort of follow-up to the original question...
I picked up a set of new shafts with my my rocke arm purchase (private sale, old but un-used parts)...these were somewhat pitted, mostly surface rust, etc, etc...but since I wanted to try my Crane adjustable 1.6 ratio arms I figured I'd clean these up and use them.
The shafts did NOT have the groves...so I marked them out, each wide enough to span the width of the rocker arm, but not so wide that it simply drains the oil out from under the rocker arm. But...I did not grove the shaft sloped (like the pics shown here), instead I simply cut the grove straight across.
I realize this is not ideal, but I figured it would be better then no grove at all since the grove would distribute the oil evenly across the rocker. Tell me though, did I screw them up? Does the straight cut introduce an easy spot for a stress fracture to develop? Should I have left them as they were?
Let's be honest, with a dremel abbrasive wheel there is only so much you can do...I kept the cut shallow, but attempting to cut the grove sloped on that round shaft surface was a NO-GO using a hand tool...
