Which Battery To Buy? #1794323
04/01/15 04:54 PM
04/01/15 04:54 PM
South San Francisco, Ca
70sixpkrt Offline OP
I need to get a new battery for my 1970 Charger. It's a choice between a 600 cold cranking amp Mopar Performance battery or a 800 cold cranking amp Optima Red Top battery. My motor is a 500 hp with 10:26-1 with MSD dist and MSD 6 AL. I was using a Optima but it only lasted 5 years. The MP battery is a lot cheaper than the Optima. Which one should I get?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Which Battery To Buy? [Re: 70sixpkrt] #1794324
04/01/15 04:58 PM
04/01/15 04:58 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
MP
Re: Which Battery To Buy? [Re: 70sixpkrt] #1794325
04/01/15 05:27 PM
04/01/15 05:27 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
If you want another option, the NAPA Legend has a 1020cca (at 32 degrees) battery for $130.
http://www.napaonline.com/Catalog/Catalo...8434_0398840662
Re: Which Battery To Buy? [Re: 70sixpkrt] #1794326
04/01/15 06:56 PM
04/01/15 06:56 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
Another option...
ODYSSEY® Extreme Racing
Re: Which Battery To Buy? [Re: STROKIE] #1794327
04/01/15 08:33 PM
04/01/15 08:33 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Or one of the 2.5 pound light weight batteries and is only $50 more than a retail optima. Tim
http://aircraftproducts.wicksaircraft.co...2&keyType=P
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Which Battery To Buy? [Re: astjp2] #1794328
04/01/15 08:58 PM
04/01/15 08:58 PM
Thanks for your suggestions but I would like to stick with the MP or Optima.
4-speed
3:54 Dana
Re: Which Battery To Buy? [Re: 70sixpkrt] #1794329
04/01/15 11:12 PM
04/01/15 11:12 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Last Optima my kid had was like 8 years old Charge it up and it was good for 6 months then it sat went low and recharge and it was good again.I run the biggest battery I can fit.I like Advance or Interstate as we sold them at work and they were always good.The Optima is nice but pricey.Rocky
Chrysler Firepower
Re: Which Battery To Buy? [Re: 70sixpkrt] #1794330
04/01/15 11:23 PM
04/01/15 11:23 PM
Zombieland
Car Nut Online laugh2
Zombieland
I use the biggest Diehard's Gold without any problems.
Re: Which Battery To Buy? [Re: therocks] #1794331
04/02/15 12:39 PM
04/02/15 12:39 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I just bought a 680cca type 35 from autozone in AGM for $170. No more leaks!
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Which Battery To Buy? [Re: AlexP] #1794332
04/04/15 01:31 AM
04/04/15 01:31 AM
4-speed
3:54 Dana
Re: Which Battery To Buy? [Re: 70sixpkrt] #1794333
04/04/15 01:57 AM
04/04/15 01:57 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I tried Optima but they did not hold up on a car that sits for any length of time. The things were always dead and would not re-charge.
Go for an Interstate, Sears DiHard Gold, or the top of the line store brand from you local retailer.
The Duracell from Same Club has been good this winter in my Mustang too.
SCOtt
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Which Battery To Buy? [Re: 70sixpkrt] #1794334
04/04/15 02:57 AM
04/04/15 02:57 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Ricky, just go down to Sears and by yourself a Diehard Gold and peel the top lable off. That is what I run in all of my rides with no issue's!
Re: Which Battery To Buy? [Re: SCATPK] #1794335
04/04/15 11:35 AM
04/04/15 11:35 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
That's not so easy any more. I went to my local Sears store yesterday to buy a battery only to find out they had closed the automotive store here I always bought my batteries.
Re: Which Battery To Buy? [Re: markz528] #1794336
04/04/15 01:33 PM
04/04/15 01:33 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
We happen to have a Sears automotive store right down the street from us that has been there for years.I have had nothing but good luck with the Diehard batteries and have always gone the distance. Plus by peeling the lables off the side, look fairly stock and blend well in the engine compartment. The factory batteries are still going strong in my 03 Dodge Ram PU and will replace with Diehards when they finally give up and not crank over its diesel engine.
Re: Which Battery To Buy? [Re: SCATPK] #1794337
04/04/15 08:00 PM
04/04/15 08:00 PM
Herb which Diehard are you using? I didn't have good luck with them in the past.
4-speed
3:54 Dana
Re: Which Battery To Buy? [Re: 70sixpkrt] #1794338
04/04/15 08:23 PM
04/04/15 08:23 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Diehard Gold. I have them in my gtx,dart,and my 2 hondas with no issues. Cant say much about their cheaper models, but the gold units have worked great. I have never used a trikle charger or disconnected a cable and even sitting for over 2 months at times always fire up! Buy the best they offer and you will be good to go.
