440 turbo cam? #17943
10/30/05 04:20 AM
10/30/05 04:20 AM
Anonymous OP
Anonymous OP
Can any one tell me what cam to use on 440 .060 over 8.5-1 comp with twin holset 35 turbos ?
Re: 440 turbo cam? #17944
10/30/05 02:04 PM
10/30/05 02:04 PM
Anonymous OP
Anonymous OP
Sounds like a question for board member "feets". You might try PMing him.
Re: 440 turbo cam? #17945
10/30/05 03:21 PM
10/30/05 03:21 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
You could start with the stock 440 cam for a baseline, the stock cams typically do well in turbo applications. You could also check a few of the big manufacturers for recommendations. Crower has two turbo-specific grinds for small blocks, which I ASSume you could have ground on big block blanks. I wasn't shopping for big block stuff back when I was doing my turbo research, so you'll have to check on that yourself.
Crower PN 31978
Crower PN 31978
They might even want to brew up something a little hotter than these two for a 440, although it's tough to go too mild on a turbo cam.
FWIW, I was planning on a single HX-40 for my 318. On paper it was making 400hp/425lbft at 8psi with the -78 cam, and 450hp/430lbft with the -79 cam. I've been using Ray Hall's site for tinkering. Desk Top Dyno 2000 seems to have some "issues" with turbo applications, even for a go-by.
Clair
Re: 440 turbo cam? #17946
10/30/05 03:25 PM
10/30/05 03:25 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i think my comp cams would work good!.550int,565 exh,230@.050,113 lsa installed 2 deg adv.
do you want a hydrolic?how much boost for a given hp you are looking for.blowthrough carbed?street or dual st.strip?
Re: 440 turbo cam? [Re: blownzoom440] #17947
10/30/05 03:41 PM
10/30/05 03:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check with FEETS. He has done a boatload of research on 440 tubos while building his twin turbo set up.
Re: 440 turbo cam? #17948
10/30/05 04:38 PM
10/30/05 04:38 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I laid out my cam and had Comp Cams cut it for me.
intake 236* @ .050" with .474" lift
exhaust 232* @ .050" with .483" lift
112 LSA and 10* of overlap at .050"
It's a rather interesting lobe. It uses fast ramps to hang the valve open longer and drops 'em quickly when closing. It's got a fairly fat lope peak for a non-roller cam.
I originally wanted zero overlap but that would have taken a custom blank. I agreed to let 'em move the lobes and add a touch of overlap to use a standard blank and cut down the cost. I paid $182 for the cam in 2001. I don't think the cost has gone up much since then.
It's a fairly nice cam. Smooth idle and good cylinder pressure. A side effect is better economy when not in the turbos.
There have been some advances in turbo cam technology in the past 5 years. You'll find more cams being cut with a taller exhaust lobe the evacuate the cylinders better. The duration is cut down to prevent reversion because you're not going to get any exhaust scavenging with a turbo building backpressure in the header. LSA has moved around a bit but seems to stay at 112 to 114 for most motors.
DO NOT use a blower cam. They're not the same and will not be happy when saddled with a turbo.
Unless someone is really going radical, you're not going to find many big cams in the turbo world. You simply build a mild engine that moves air smoothly. It's not necessary to hog out the heads within an inch of their lives. You simply make sure the air can get in and out with a minimum of fuss. Look at mid lift numbers and ignore everything over .500" lift. You're not going up there so don't waste your time. Those big number heads can have horrible low speed air behavior and that's what you want to avoid.
Make it smooth, mild, and cram the air in. You'd be suprised what you'll get.
My stock 906 head combo with a Torker II intake and this cam managed to crank out 657 hp and 742 tq at the wheels using a nicely massaged 850 carb, 17 psi, and alcohol sprayed through a nitrous style needle.
I don't know what it'll do with EFI. Hopefully I won't over time the engine and rattle the head gasket out like I did on that last run.
- Stu Harmon
Re: 440 turbo cam? [Re: feets] #17949
10/30/05 05:53 PM
10/30/05 05:53 PM
ELYRIA,OH
ELYRIA,OH
to me the cams look cept mine has more exh lift that u recamend and more lift which i feel is better then boost heat.i can see going hydrolic but the spring pressure u need is greater so a good mech valve assy is need anyways.
i just wanted to point out the simalerities of the cams not debate them.
AKA"ZOOM"
Re: 440 turbo cam? [Re: blownzoom440] #17950
10/31/05 09:53 AM
10/31/05 09:53 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Yeah, blower cams use a little more exhaust duration. Adding overlap helps push a little more exhaust out for a cleaner burn. You can get a good scavenge that way but it costs a bit of efficiency.
With a cam built on those specs, you will need a little better valvetrain for piece of mind. My setup uses the ancient stock stamped rockers.
Sounds like you've got a fun little toy.
- Stu Harmon
Re: 440 turbo cam? [Re: feets] #17951
10/31/05 11:40 AM
10/31/05 11:40 AM
ELYRIA,OH
ELYRIA,OH
i have the same duration but more lift.ya i know about overlap!!the isky cam i had had 81 deg of it and with a pully for 24lbs i got 6lbs so i switched to the comp cam and adjusted for the overlap.it is a long story i will post on in a few days.[my motor experiance boosted]
