70 rr doors on a 69?? are they the same #179407
12/31/08 02:40 AM
12/31/08 02:40 AM
st.charles,mo.
dodgem1 Offline OP
dodgem1  Offline OP
st.charles,mo.
hi,will 1970 rr doors fit on a 69 r-r,are they the same thanks-jeff
Re: 70 rr doors on a 69?? are they the same [Re: dodgem1] #179408
12/31/08 02:44 AM
12/31/08 02:44 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes
Re: 70 rr doors on a 69?? are they the same [Re: dodgem1] #179409
12/31/08 03:59 PM
12/31/08 03:59 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
1968 and 1969 Coronet doors will work also,not sure about 1970.
Re: 70 rr doors on a 69?? are they the same [Re: Ply72rr] #179410
12/31/08 04:02 PM
12/31/08 04:02 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
68 doors are different where the lock is on the inside.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 70 rr doors on a 69?? are they the same [Re: RoadRunner] #179411
12/31/08 04:28 PM
12/31/08 04:28 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
As mentioned 68 doors have the inside lock further rearward..69 & 70 Plymouth & Dodge except Charger B body doors interchange, 68 if you weld up holes & redrill in the correct location....
Re: 70 rr doors on a 69?? are they the same [Re: 1_WILD_RT] #179412
12/31/08 07:00 PM
12/31/08 07:00 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
70 Coronet has the same door too.
I think there is an additional internal cross support in the 70 door but it makes no difference to fit or appearance.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: 70 rr doors on a 69?? are they the same [Re: 69superbee383] #179413
01/01/09 01:03 PM
01/01/09 01:03 PM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
Be aware the window glass is different for coupe and hardtop.
