Speedometer Gear #179382
12/31/08 02:17 AM
12/31/08 02:17 AM
Marine Corps Base Hawaii
DemonKyle Offline OP
USMC LCPL
USMC LCPL
What color gear do I need for my car. I just put an 8 3/4 into it and the tranny is a 904.
Kyle
Re: Speedometer Gear [Re: DemonKyle] #179383
12/31/08 02:31 AM
12/31/08 02:31 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
You need to supply gear ratio and tire diameter.
Re: Speedometer Gear [Re: DemonKyle] #179384
12/31/08 02:31 AM
12/31/08 02:31 AM
put a piece of flat stock on top of one of your rear tires & measure the distance from the underside of it to ground(actual tire height) & you know your new gear ratio. With those (2) figures go into the archives & find the part # of the correct speedo pinion you need. Dont know if they're listed by color or not.
Re: Speedometer Gear [Re: DemonKyle] #179385
12/31/08 02:31 AM
12/31/08 02:31 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
find the gear selection chart in the archives. you will need to know your rear gear ratio, tire size RPM..
I am truckless..
