Re: Voltage regulator going bad on a Ram 1500?
[Re: 70sixpkrt]
#179375
12/31/08 07:56 AM
12/31/08 07:56 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
in the 1994 to 1998 Rams a lot of the headlight switches went bad. I would have thought that a 2000 would have had an improved design but you might be suspicious of the switch you might look through the TSB's here: http://dodgeram.info/tsb/index.htmlI also agree that bad ground connections can lead to all kinds of weird symptoms in Rams
[Re: 360view]
#179376
12/31/08 02:49 PM
12/31/08 02:49 PM
Posts: 3,682 South San Francisco, Ca
70sixpkrt
I will check the grounds. I always thought that if you had problems with a PCM your engine check light will go on the dash. My engine check light has not gone on. Thanks for the link on the TSB's.
