70 Challenger SE emblem location. #1792831
03/31/15 08:14 PM
03/31/15 08:14 PM
Downtown Roebuck Ont
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Is there a template or diagram available to locate the SE emblem on the sail panel (C pillar?)?
My buddy just got his RT/SE back from the body shop and for what ever reason, the guy filled in the holes. He did a fine job too because they are GONE without a trace.
This isn't a concourse resto but if there is a way to install the new emblems "correctly", he would prefer it be done that way.
Kevin
Re: 70 Challenger SE emblem location. [Re: Twostick] #1792832
03/31/15 09:26 PM
03/31/15 09:26 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Can't see anything from the inside? Should be able to by removing the interior sail panel. It just pulls off like a door panel clip. Maybe some body filler seeping through the original hole?
Re: 70 Challenger SE emblem location. [Re: Suregrip391] #1792833
04/01/15 05:45 PM
04/01/15 05:45 PM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Apparently all the internal bracing blocks the view.
He went thru that trying to figure out how to get the emblems off without wrecking them. He thought they had nuts on the backside. No access from the inside.
Kevin
Re: 70 Challenger SE emblem location. [Re: Twostick] #1792834
04/01/15 11:34 PM
04/01/15 11:34 PM
CA
cudino Offline
cudino  Offline
CA
Is this emblem mounted by just a single hole/screw? If so I can help, my SE has the vinyl top off right now and I can take pictures/measurements. But I only see one ~1/4" hole.
- Wade
Re: 70 Challenger SE emblem location. [Re: cudino] #1792835
04/02/15 01:38 AM
04/02/15 01:38 AM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
- Wade
I believe it has just the one pin. Is there an insert that it pushes into or does the pin taper that much? As I recall the emblem just pushes in.
If you could send pics/measurements, that would be great. My E-mail should be in my profile.
Kevin
Re: 70 Challenger SE emblem location. [Re: Twostick] #1792836
04/02/15 03:34 AM
04/02/15 03:34 AM
CA
cudino Offline
cudino  Offline
CA
OK, just sent you some pics and dimensions, let me know if that works.
- Wade
Re: 70 Challenger SE emblem location. [Re: cudino] #1792837
04/02/15 04:25 PM
04/02/15 04:25 PM
CA
cudino Offline
cudino  Offline
CA
I couldn't post pics yesterday so I just emailed, but I got another request for these pics so here they are. I had this hole covered in duct tape, so what you see around the hole is just the ugly residue.
It is about a 1/4" hole, about 3 1/4" above the centerline of the lower moulding, and 4 1/4" (horizontal to the ground) from the center of the C-pillar moulding. And yes, there's stuff in the way on the inside of the roof so you can't see the hole.
This is an original, unrestored roof/car, but it has been primered after the top was removed.
Hope this helps,
- Wade
Re: 70 Challenger SE emblem location. [Re: cudino] #1792838
04/02/15 04:26 PM
04/02/15 04:26 PM
CA
cudino Offline
cudino  Offline
CA
#2
Re: 70 Challenger SE emblem location. [Re: cudino] #1792839
04/02/15 04:26 PM
04/02/15 04:26 PM
CA
cudino Offline
cudino  Offline
CA
#3
Re: 70 Challenger SE emblem location. [Re: cudino] #1792840
04/03/15 12:47 PM
04/03/15 12:47 PM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
I forwarded the pics to my buddy and he says they will help a bunch.
Thanks again.
Kevin
