What cylinder pressure on pump gas? #1792663
03/31/15 04:55 PM
03/31/15 04:55 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Changing my Hemi over to pump gas. What cylinder pressure can I get away with on 92 pump gas? All aluminum 4.50 bore motor.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: What cylinder pressure on pump gas? [Re: 65 Hemi] #1792664
03/31/15 04:59 PM
03/31/15 04:59 PM
an8sec70cuda Offline
Mine has 185 psi.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What cylinder pressure on pump gas? [Re: an8sec70cuda] #1792665
03/31/15 05:32 PM
03/31/15 05:32 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Mine has 185 psi.
Thanks.
Doug
MOPAR or NO CAR!!!
Re: What cylinder pressure on pump gas? [Re: 65 Hemi] #1792666
03/31/15 05:48 PM
03/31/15 05:48 PM
You're welcome. My 14:1 wedge motor also has 185 psi...definitely not running pump 93 in that one though.
CHIP
Re: What cylinder pressure on pump gas? [Re: an8sec70cuda] #1792667
03/31/15 06:45 PM
03/31/15 06:45 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Yes, it's a little tougher to run that high of cylinder pressure in a wedge.
Doug
MOPAR or NO CAR!!!
Re: What cylinder pressure on pump gas? [Re: 65 Hemi] #1792668
03/31/15 08:15 PM
03/31/15 08:15 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I run 93 octane in my small block and I have 195-201 lb cranking cylinder pressure. 10.9-1 comp, .255/.266 @.050 camshaft with aluminum heads. Distributor locked out at 35 degrees.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: What cylinder pressure on pump gas? [Re: D-50] #1792669
04/01/15 12:44 PM
04/01/15 12:44 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Bump. Anybody else?
Doug
MOPAR or NO CAR!!!
Re: What cylinder pressure on pump gas? [Re: 65 Hemi] #1792670
04/01/15 01:08 PM
04/01/15 01:08 PM
The wedge had 275 psi before I changed the cam.
CHIP
Re: What cylinder pressure on pump gas? [Re: 65 Hemi] #1792671
04/01/15 01:22 PM
04/01/15 01:22 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Not a Hemi, but mine is at 185 with RPM heads and iron block. Cr is 11.8. I run 93 octane pump gas.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: What cylinder pressure on pump gas? [Re: 68LAR] #1792672
04/01/15 04:18 PM
04/01/15 04:18 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I crank at 170, I run 9s on local 93 gas.
Mopar Performance
Re: What cylinder pressure on pump gas? [Re: moparniac] #1792673
04/01/15 06:26 PM
04/01/15 06:26 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have 190s on pump puke.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: What cylinder pressure on pump gas? [Re: 1967dartgt] #1792674
04/01/15 08:28 PM
04/01/15 08:28 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
212 psi is a little too high.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: What cylinder pressure on pump gas? [Re: 65 Hemi] #1792675
04/01/15 08:33 PM
04/01/15 08:33 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Cylinder pressure is not directly related to compression ratio. You need to know cam specs, bore, stroke, rod length, static compression, and valve closing angle. other wise you're just guessing.
Re: What cylinder pressure on pump gas? [Re: 65 Hemi] #1792676
04/01/15 08:43 PM
04/01/15 08:43 PM
gregsdart Offline
gregsdart  Offline
There was a point made in one of the posts on compression and pump gas that the true test is how well it will run when the motor hits the peak torque area where max volumetric efficiency is achieved. With a big cam and high compression the motor will still need the octane to handle the static (not cranking) compression due to ram intake and exhaust tuning.
Re: What cylinder pressure on pump gas? [Re: 1980volare] #1792677
04/02/15 10:17 AM
04/02/15 10:17 AM
Just b/c my wedge cranks 185 psi doesn't mean it'll run on 93. It still has the same 14+:1 compression it did before when it cranked 275 psi...the cam is the only difference.
The compression ratio still needs to be on the low end (for the most part) to be pump gas friendly.
CHIP
Re: What cylinder pressure on pump gas? [Re: 65 Hemi] #1792678
04/03/15 01:50 PM
04/03/15 01:50 PM
Windsor, ON, Canada
Diplomat360 Online content
Diplomat360  Online Content
Windsor, ON, Canada
360 mopar, 9.8:1 CR, 175 PSI cranking with a Hughes hydraulic flat tappet cam: 238/244 @ 0.050, with nasty/crappy quench on stock heads. I run 93/94 pump gas...pretty aggresive advance curve: 21 idle@900, 35 @2000. No ping.
Re: What cylinder pressure on pump gas? [Re: Diplomat360] #1792679
04/03/15 05:22 PM
04/03/15 05:22 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
360 mopar, 9.8:1 CR, 175 PSI cranking with a Hughes hydraulic flat tappet cam: 238/244 @ 0.050, with nasty/crappy quench on stock heads. I run 93/94 pump gas...pretty aggresive advance curve: 21 [Email]idle@900[/Email], 35 @2000. No ping.
I would advance final timning even more on that one. All my low compression 340's and 360's liked at least 38...
And for the nay sayers, you can run 14:1 on pump gas....Its called water injection and it works really well. If you can tune a carb, you can tune a water injection system. We have guys tired of paying for race fuel and went this route and will never look back.
Re: What cylinder pressure on pump gas? [Re: Dragula] #1792680
04/06/15 09:28 AM
04/06/15 09:28 AM
pa
572charger Offline
572charger  Offline
pa
my 606 cuin hemi is 180 psi it is at 12 to 1 comp i run it on pumpgas 93 octane with the total timming at 32 degrees and take out 8 degrees on the spray !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: What cylinder pressure on pump gas? [Re: 572charger] #1792681
04/06/15 11:58 AM
04/06/15 11:58 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
With a loose verter you can get away with 185-195 all day long. Go to a manual trans with the same setup and plan on taking about 5-6 degrees out of total timing or it will be ping city.
Mopar to the bone!!!
Re: What cylinder pressure on pump gas? [Re: Dragula] #1792682
04/06/15 12:34 PM
04/06/15 12:34 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Who is doing water injection? Can you please give more info on this?
Doug
MOPAR or NO CAR!!!
