whats the largest valve lift with j heads and kb piston
#1792136
03/31/15 12:00 AM
03/31/15 12:00 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
what is a reasonably decent max valve lift I can go on a set of heavily ported and modified J heads with kb hyper 107 pistons and what valve springs to go with it? I have a set of solid roller lifers I may use also. I am looking for someone with technical experience on high lifts with kb 107 pistons and or J heads.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
Re: whats the largest valve lift with j heads and kb piston
[Re: 76Beeper]
#1792138
03/31/15 05:09 PM
03/31/15 05:09 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Clearance will also vary if you advance or retard the cam from the checking point.
[Re: 76Beeper]
#1792140
03/31/15 11:07 PM
03/31/15 11:07 PM
cheapstreetdustr
I am going to have to either go with a custom exhaust lobe .. or find some 1.6 exhaust rockers.i have 1.5 exhaust rockers in it now.
I have stage 5 offset intake rockers that are 1.6 the cam I have in it was custom made and has a larger exhaust lobe to compensate for the 1.5 exh rocker I was using.. they are hand me downs jesels. My issue is I want to use the air that these heads flow. they peak around .570" I don't want piston to valve interference either. and was looking .to build a cam I can check piston to valve clearences now but not sure at what piston/crankshaft *degree to check it at before and after tdc..
