Fuseable Link #179203
12/30/08 09:25 PM
12/30/08 09:25 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
who would have the correct 1966 B body hemi fuseable link, I could purchase,thanks
Re: Fuseable Link [Re: 426lloyd] #179204
12/30/08 11:25 PM
12/30/08 11:25 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Is the same link used on the 66 Coronet with a small block? I save all my old harnesses and you can have it if it's the one you need. I'll check the schematic to find out where it's located and then my harness to see what condition it's in. As I recall they come off the starter relay?
Re: Fusible Link [Re: 426lloyd] #179205
12/31/08 04:11 AM
12/31/08 04:11 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
If all else fails.
Year One Don't forget your Moparts 15% discount when ordering. Code - MOPARTS15
From the YO part number, it looks like they may still be available from the dealer.
Re: Fuseable Link [Re: Snoopy] #179206
12/31/08 08:22 AM
12/31/08 08:22 AM
okla.
O
okie Offline
okie  Offline
O
okla.
I just seen new fusible links at the local NAPA. Good Luck! Ronnie in Okla.
Re: Fuseable Link [Re: Lefty] #179207
12/31/08 05:47 PM
12/31/08 05:47 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
the link goes from the starter solenoid to the horn relay and is violet in color.these relays on 66 hemi cars are on a bracket attached to the inner fender so the link would not be too long
