Racing w/dual quad - A NSS #1791206
03/29/15 03:50 PM
03/29/15 03:50 PM
New Hampshire, USA
O
oldiron Offline OP
oldiron  Offline OP
O
New Hampshire, USA
I'm setting the car up to be able to run NMCA rules. My goal is A NSS so I'm going dual Edelbrock performer carbs & indy modman. I'm figuring on shifting at about 7K, not launching on a 2 step, & launching at 5 to 5500. I haven't played with an ebrock carb in a bunch of years, & thinking 2 600s
This is a 470 w/SRs, 456 gears, 3.08 1st gear
So am I opening a bad can of worms?
600s ok?
anything to be done as far as playing with the counterweights on the secondary air door? (It looks like no AVS for my car, but not sure)
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Racing w/dual quad - A NSS [Re: oldiron] #1791207
03/29/15 04:10 PM
03/29/15 04:10 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
We've had good luck with the 600's on the smaller motors, 750's on the bigger stuff. In years past I watched guys with sticks take the air door completely out. Stock jetting is very close. You may want to swap the step-up springs so the metering rods stay seated in the jet at idle. I think that these carbs biggest down fall is there transition from idle/leave rpm to WOT. Whether it is lack of pump, air door to quick/slow I haven't figured out yet. They're not terrible but there is room for improvement. I see a few AVS but they don't appear to be any better. Even the 800's on a big motor. My 572 A/FX car runs 2 750's at 113 square jetting. I've moved it around a couple of times with minimal change. My buddy's 440 (N/SS D) runs stock 600's and stock jet, same deal runs about the same. With a stick I'd use the two step in a heart beat. I can't with an automatic or I would.
Doug
Re: Racing w/dual quad - A NSS [Re: dvw] #1791208
03/29/15 04:26 PM
03/29/15 04:26 PM
New Hampshire, USA
O
oldiron Offline OP
oldiron  Offline OP
O
New Hampshire, USA
Thanks Doug,
W/r to the 2 step. I've been gun shy since I had a switch fail and launched at 7500. I was planning on bringing it up to where the 2 step just starts acting and then backing off. Thinking this will give some pump shot left. I'll probably work my courage up again and give it a try w/pedal to the floor.
Thanks again
Greg
Re: Racing w/dual quad - A NSS [Re: oldiron] #1791209
03/30/15 04:30 PM
03/30/15 04:30 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
what car and what does it weigh? What are your engine specs?
I run a modman with a pair of 600s on a 499 with SRs and a small indy flat tappet cam at 12.5 to 1 comp. My car weighs 3550 and I ran a best of 9.99 with mine in NSS trim. Not enough room to work in bad weather. I backed mine up to B due to that.
Re: Racing w/dual quad - A NSS [Re: 66coronet] #1791210
03/30/15 09:40 PM
03/30/15 09:40 PM
New Hampshire, USA
O
oldiron Offline OP
oldiron  Offline OP
O
New Hampshire, USA
68 barracuda, 3200 to 3250 depending on the day on new england dragway scales, solid roller, .646 lift, 11 to 1, MW port SR heads by Dwayne. 470ci
It will typically run 9.90 to 95 at new england until the temp gets over 85 then will be up to 10.0 to 10.05 w/1050 4150 version. This is with no tuning for weather. Planning on raising the compression ratio, not too much left in the heads, will be a cam change. Going for 9.80s when hot.
I'm planning on testing the modman and edelbrocks with no other changes to see the effect from just those.
Did you ever try a before and after with the modman?
Re: Racing w/dual quad - A NSS [Re: oldiron] #1791211
03/30/15 10:23 PM
03/30/15 10:23 PM
AndyF Offline
AndyF  Offline
Why the ModMan rather than the Indy X ram? Is the X ram not legal in the class?
The ModMan might work better than the Edelbrock dual carb intake just because the Modman is single plane rather than dual plane, but the ModMan is a weird intake. Basically just a big box with little short runners. You might need to do some serious tuning to get all 8 cylinders happy at WOT.
Re: Racing w/dual quad - A NSS [Re: AndyF] #1791212
03/30/15 10:40 PM
03/30/15 10:40 PM
New Hampshire, USA
O
oldiron Offline OP
oldiron  Offline OP
O
New Hampshire, USA
I never saw a low deck cross ram listed by Indy
Is there such a thing?
Re: Racing w/dual quad - A NSS [Re: oldiron] #1791213
03/30/15 11:38 PM
03/30/15 11:38 PM
AndyF Offline
AndyF  Offline
Didn't realize it was a low deck. Yeah, not many choices for low deck intakes. Gotta run what you can find I guess.
Re: Racing w/dual quad - A NSS [Re: AndyF] #1791214
03/30/15 11:41 PM
03/30/15 11:41 PM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
STR-15
Re: Racing w/dual quad - A NSS [Re: oldiron] #1791215
03/30/15 11:42 PM
03/30/15 11:42 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
I don't have good data on the swap. I went 9.91 @137 with the indy single plane and 950hp with a fuel delivery issue.
We fixed the fuel problem and went to the modman and 600s at the same time. I saw .08 slower with the modman without tuning for best et. We got a base line and tuned for consistency. We were on a short time table for the first NMCA race a few years back. Honestly, we have just left it alone and let it work for us.
To answer Andy F... It fit under my hood, so I went with it over the indy bathtub.
Re: Racing w/dual quad - A NSS [Re: 66coronet] #1791216
03/31/15 02:09 PM
03/31/15 02:09 PM
NJ
cb1289 Offline
cb1289  Offline
NJ
Greg,
My experience this past season has been similar to what dvw stated about the transition off idle to wot. It works but could be more responsive at the hit. Overall it still was consistent & reliable, but not as good as a holly. This is with 2 eddy 750cfm afb, mod man,493 rb,3700lb auto.Don't know how it would act with your stick shift combo.
Steve
PS- I think the mod man is a good compromise manifold for performance & fitting under a stock hood. Went 10.70's & 80's with a ch-28 & 500cfm afb's 2 seasons ago & 10.40's & 50's last season with the mod man & 750's
62 Dodge Dart Wagon 65 Plymouth Satellite
Re: Racing w/dual quad - A NSS [Re: cb1289] #1791217
03/31/15 04:32 PM
03/31/15 04:32 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
Maybe a dumb question but I know the A bodies with a wedge are legal with a single 4 intake and the NMCA will allow you to run a Holley. Why complicate your life? Unless you are looking for that look then I understand.
Re: Racing w/dual quad - A NSS [Re: biff426] #1791218
03/31/15 05:45 PM
03/31/15 05:45 PM
Wi.
old_racer Online content
old_racer  Online Content
Wi.
can't run a holley single four barrel on a mopar unless your in the fx 9.75 and quicker classes I'm pretty sure.
Re: Racing w/dual quad - A NSS [Re: old_racer] #1791219
03/31/15 06:30 PM
03/31/15 06:30 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
Correct Russ. 9.75 you can run a Holley (c/fx). You can run a single afb in the slower classes though.
Casey
Re: Racing w/dual quad - A NSS [Re: cb1289] #1791220
03/31/15 11:05 PM
03/31/15 11:05 PM
New Hampshire, USA
O
oldiron Offline OP
oldiron  Offline OP
O
New Hampshire, USA
Thanks Steve, good to know. Hood clearance is an issue. It will be interesting. I may have to leave with the pedal all the way down. This is going to be a learning process. There will be a bunch of clutch adjustments to get everything working.
Yes, AFBs it is for NSS. I didn't think I'd be able to run the 10.00 index with one. Maybe someone more clever than me could.
Re: Racing w/dual quad - A NSS [Re: oldiron] #1791221
04/01/15 12:58 AM
04/01/15 12:58 AM
SC
Greg Offline
Greg  Offline
SC
Give Damon at Diamondback Engines a call. He is the man when it comes tuning the Edelbrocks. His website is http://www.diamondbackengines.com/
Re: Racing w/dual quad - A NSS [Re: old_racer] #1791222
04/01/15 01:35 PM
04/01/15 01:35 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
I know a few years ago Heath Shemwell ran a 68 cuda with a 440 and a holley carb. He lobbied the rules committee to allow the holley carb and they allowed him to run it. I see the current rules do not I would call the NMCA and ask. Also I know the 422 guys allow it.
Re: Racing w/dual quad - A NSS [Re: biff426] #1791223
04/01/15 08:33 PM
04/01/15 08:33 PM
New Hampshire, USA
O
oldiron Offline OP
oldiron  Offline OP
O
New Hampshire, USA
I guess I'm not surprised that the rules aren't necessarily the rules,
but the die is cast. 2 4bbls it is. Something new
Re: Racing w/dual quad - A NSS [Re: oldiron] #1791224
04/01/15 09:31 PM
04/01/15 09:31 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Two AFB's aren't nearly as bad as everyone thinks. My bet is 2 Eddys will run every bit as well as a single 4150 Holley. The tuning window has been a no brainer. My car has been 9.12@147.7 On box stock 750 Eddy's with the chokes removed and nothing but one step up in jets and a spring change.
Doug
Re: Racing w/dual quad - A NSS [Re: dvw] #1791225
04/04/15 11:15 AM
04/04/15 11:15 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
oldiron,
I also run NSS, and use 2 of Damon's modified 800 Eddies on an Eddie STR-15 intake, with a Jerico. I launch on a 2 step at 5400. Combo is a 496" with INDY -1's. With screens it fits under the hood with the scoop.
Love my carbs. Engine is making more than enough steam for what I want to do with it. Last season was my first in a car this quick, and I was fighting 60' issues. Looking to keep it at a 10.0 this year and will have to slow it down.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
