440 Source Stroker Kit Pilot Bearing #1791190
03/29/15 03:43 PM
03/29/15 03:43 PM
Spring Hill Fl
65Fury440 Offline OP
Spring Hill Fl
Anyone know what the correct size pilot bearing would be? Can't get to it on the stand.
I'm wanting to spend money on a Sunday before it gets spent on bills.
Re: 440 Source Stroker Kit Pilot Bearing [Re: 65Fury440] #1791191
03/29/15 04:04 PM
03/29/15 04:04 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Its just a standard mopar pilot bearing !!
Re: 440 Source Stroker Kit Pilot Bearing [Re: Stanton] #1791192
03/29/15 04:21 PM
03/29/15 04:21 PM
Spring Hill Fl
Spring Hill Fl
Good to know, thanks!
I'll get one of these.
Mopar Part # 53009181AB
http://www.amazon.com/Mopar-9181AB-Clutch-Pilot-Bearing/dp/B0049EEV4Y
Re: 440 Source Stroker Kit Pilot Bearing [Re: 65Fury440] #1791193
03/29/15 05:42 PM
03/29/15 05:42 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'd go with the bushing, not the bearing.
Re: 440 Source Stroker Kit Pilot Bearing [Re: 65Fury440] #1791194
03/29/15 07:21 PM
03/29/15 07:21 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Just my not all aftermarket cranks are drilled for a pilot bearing. My Eagle crank wasn't even drilled deep enough for a stickshift application I had to cut almost 3/4" off the pilot of my brand new Richmond 5-speed.
I prefer the bronze insert bearing that goes into the torque converter register although I have heard it's getting hard to find.
The roller bearing type will also work well too.
Gus
64 Plymouth Savoy
Dana 60
