Re: 440 popping out the exhuast bad
[Re: stumpy]
#1790662
03/29/15 03:02 AM
03/29/15 03:02 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Once you're confident that the plug wires are correct and all other obvious tuning stuff is checked, I'd pull the intake and take a good look at the cam lobes. DAMHIK.
[Re: BigBlockMopar]
#1790668
03/29/15 12:44 PM
03/29/15 12:44 PM
Posts: 1,277 USA IN
E85-408
USA IN
He is pretty sure that it isn't a vacuum leak but I pitched an idea to him that he likes and will try after the heads get checked. Make 2 plates to block off the carb holes on the intake and put a fitting in one with the rocker arms off and see if the motor will hold a vacuum. No clue on idle vacuum from before and now, he never checked. I wanted him to do a leak down test but no equipment for that right now. I did ask if it pops through out the rpm range and he said that it fires right up but just doesn't want to take any throttle at all or any load on the motor. Also he pulled both vacuum caps off the base of the carbs and it made zero difference. That makes me think vacuum leak but he can't seem to locate it. He has had the intake off at least 4 times with a different gasket each time and no change. This is now the 5th month since the head swap and still not running. The knot at the end of his rope is getting closer and closer.
[Re: E85-408]
#1790676
03/30/15 10:42 AM
03/30/15 10:42 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Solid flat cam with what looks like very old Isky adjustable rockers.
He said the travel over the valves tips looks good using the blue dye to see it.
I'd set the lash w/ a gauge. Do you guys have access to a single 4bbl intake and carb? If so I'd try that. As mentioned you could be lean however it should run some. I'm still going w/ a vacuum leak some place. Did you see oil in the intake ports?
