diff between 750hp & 950hp #1790576
03/28/15 09:15 PM
03/28/15 09:15 PM
Richmond Twp. Mi.
Mr340 Online content OP
Mr340  Online Content OP
Richmond Twp. Mi.
Looking at the specs on holley's page it looks like they both use the same main body, 1 3/8" venturi's but the 750 uses a
1 11/16" base plate and the 950 uses 1 3/4". I can't find any #'s for the main body. the metering block are a diff#.
So the Question is can I take a 750hp main body and use a 1 3/4 base plate to make a 950? obviously there will be some tuning required but will the bigger base plate bolt up?
Gary.
Re: diff between 750hp & 950hp [Re: Mr340] #1790577
03/28/15 09:45 PM
03/28/15 09:45 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
you could probably do the swap with no issues but don't expect the hybrid to flow 950cfm. why? because a 950hp won't even flow 950cfm. it's just marketing numbers. i'm not telling you to do it or not to do it. just don't expect anything magical because it ain't gonna happen.
Re: diff between 750hp & 950hp [Re: lewtot184] #1790578
03/28/15 10:50 PM
03/28/15 10:50 PM
Richmond Twp. Mi.
Richmond Twp. Mi.
not expecting anything magical just looking for a slight improvement. I started with a 750vs and now an 800dp and I picked up a 750hp main body and am debating, keep it a 750 or convert to 950,
What's involved? just a base plate swap or are there some passages that would need to be modified?
Re: diff between 750hp & 950hp [Re: Mr340] #1790579
03/28/15 10:55 PM
03/28/15 10:55 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
200
[img] [/img]
Re: diff between 750hp & 950hp [Re: clonestocker] #1790580
03/28/15 11:38 PM
03/28/15 11:38 PM
Richmond Twp. Mi.
Richmond Twp. Mi.
Re: diff between 750hp & 950hp [Re: clonestocker] #1790581
03/29/15 10:53 AM
03/29/15 10:53 AM
pennsylvania
poboyengineering Offline
pennsylvania
When I saw this post, my first thought was who would be first to say it.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: diff between 750hp & 950hp [Re: poboyengineering] #1790582
03/29/15 11:18 AM
03/29/15 11:18 AM
Wisconsin
BIGS Offline
BIGS  Offline
Wisconsin
Mr340....the problem with doing what your talking about is the body of the 750 isnt opened up to match the 1.750 size baseplate like a true 950 body is....so you will basically not really gain a darn thing.....The 750 body is sized to match the 1.720 baseplate.....build on.....Jesse @ BIGS!!
Jesse & Lynn BIGS Performance Products Building Street/Strip Carburetors since 1974 www.bigsperformance.com
Re: diff between 750hp & 950hp [Re: poboyengineering] #1790583
03/29/15 11:26 AM
03/29/15 11:26 AM
Az
Crizila Offline
Crizila  Offline
Az
Saw that too, but didn't feel snidey enough to do it yesterday.
Fastest 300
Re: diff between 750hp & 950hp [Re: BIGS] #1790584
03/29/15 12:07 PM
03/29/15 12:07 PM
Richmond Twp. Mi.
Richmond Twp. Mi.
So then the 950 does use a diff. body than the 750. i guess thats the question I was askin'.
Thanks Jesse
And to the rest of you comedians
