Re: Crankshaft reuse?
[Re: mr111]
#1790548
03/29/15 05:16 AM
03/29/15 05:16 AM
Posts: 25,823 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Don't think of them as pits, think of them as oil reservoirs.
[Re: NITROUSN]
#1790553
03/30/15 12:26 PM
03/30/15 12:26 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
The pits are between the rod bearings. I don't see how that would hurt anything. If you want to run it I would. If you want a stroker for more power I understand. Make it for pump gas.
2011 Drag Pak Challenger
[Re: mr111]
#1790561
03/31/15 06:22 PM
03/31/15 06:22 PM
Posts: 43,205 Bend,OR USA
Cab_Burge
The main advantage of using the BB Chevy type forged steel H beam rods is the better 7/16 rod bolts,much stronger rods than stock, new materials, less cost and weight The longer rods help reduce the side loading on the cylinder walls also I have a 464 C.I. 440 block pump gas motor that I had the stock crank offset ground down to BB Chevy rod sizes and increased the stroke to 3.900 or 3.910, CRS disease I used a 7.100 long BB Chevy type rod in that motor to help reduce the cylinder wall loading and help reduce the weight of the pistons also I'm building another pump gas 440 stroker motor right now that is 4.250 stroke with 6.800 long Eagle BB Chevy type rods, I'm using them because I had them in stock and wanted to use them up. I would have bought 7.100 long rods if I didn't have this set of Eagles on the shelf IHTHs
