Holes in my Heads??? #179050
12/30/08 07:41 PM
12/30/08 07:41 PM
Toronto Ontario
Butt Ugly Offline OP
Toronto Ontario
Looking at headers for my smogger 360 and I need to fill the Air Holes in the Heads.
Any one know if I have to tap them and some set screws?? OR what is the best method to plug the Air Holes.
Jeff
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
Re: Holes in my Heads??? [Re: Butt Ugly] #179051
12/30/08 08:29 PM
12/30/08 08:29 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
tap them then use set screws w/lock tite
Re: Holes in my Heads??? [Re: Butt Ugly] #179052
12/30/08 08:41 PM
12/30/08 08:41 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Clean out good and fill with some JB and smooth the surface. works well and is easier than tapping for screws.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Holes in my Heads??? [Re: Butt Ugly] #179053
12/30/08 08:43 PM
12/30/08 08:43 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
If the heads are off then tap away. I have plugged them before by removing the air pulse tube, cutting it off close to the head (bout 1/2 inch) then epoxying a copper pipe cap on the end. Then simply bolt the 'homemade cap' back on.
Re: Holes in my Heads??? [Re: MoparforLife] #179054
12/30/08 08:52 PM
12/30/08 08:52 PM
Toronto Ontario
Toronto Ontario
Thanks for the info, this will be a first for me, do the passages go to the combustion chambers??
and sorry for the lame question, " clean and fill with JB " what's JB??
Re: Holes in my Heads??? [Re: Butt Ugly] #179055
12/30/08 09:01 PM
12/30/08 09:01 PM
Upper Midwest
Upper Midwest
JB weld. Works real fine. Never had one fail and I run with headers.
Re: Holes in my Heads??? [Re: Butt Ugly] #179056
12/30/08 09:23 PM
12/30/08 09:23 PM
The holes go into the ex ports. JB weld comes in clear blister pack with 2 toothpaste like tubes of goo, 1 black & 1 white. Any parts house will stock it. Just mix an equal amt from each tube thoroughly until it is grey, clean the holes with a shot of starting fluid & plug them up, let it set up in a warm garage.
Re: Holes in my Heads??? [Re: RapidRobert] #179057
12/31/08 04:37 AM
12/31/08 04:37 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Not sure if this is still the case, but back in the 1980's, small block headers came with a bag of plugs that you could just hammer into the holes.
