Starting Pull Engine/Trans from Bottom.. Tips/Advice?
#179003
12/30/08 04:52 PM
12/30/08 04:52 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
It took forever but I FINALLY have everything ready to pull the drivetrain from the bottom now that my dolly and casters are finished. Looks like I also may have some time tomorrow to actually I know that I need to remove the Torsion Bars first. Should I mark or score anything to help with the cars alignment whenever I get ready to reassemble? Any recommended order of sequence for disassembly doing it this way since I have only pulled motor/trans from top. Thanks a bunch guys, Joe
65 Barracuda 70 Challenger
Re: Starting Pull Engine/Trans from Bottom.. Tips/Advice?
[Re: jrwoodjoe]
#179004
12/30/08 05:29 PM
12/30/08 05:29 PM
Posts: 16,137 Mesa, Arizona
dart4forte
Mesa, Arizona
Good luck with the project. Real easy to do. make sure everything is unhooked and check it twice. Since this something we don't always do double checking everything before dropping the assembly will pay off. As far as putting everything back, the only thing I would recomemnd is making some guide pins for the K member bolt holes. Find some threaded bar stock the same size as the K member bolts. This will help align the bolt holes when you put it back in. You'll also want to support the tranny tailshaft while you are installing the cross member.
[Re: dart4forte]
#179005
12/30/08 07:25 PM
12/30/08 07:25 PM
Posts: 1,672 Virginia
HemiStan
Virginia
Pop the upper ball joints apart and leave the upper control arms attached to the car. Everything else "should" remain the same as far as alignment.
[Re: HemiStan]
#179007
12/30/08 10:51 PM
12/30/08 10:51 PM
Posts: 2,304 WI
RestoRick
WI
Another option is to unbolt the lower ball joint/steering arm from the spindle rather than popping the upper joint.
