SB bracket racers, what spark plugs you running?
#1789773
03/27/15 11:12 PM
03/27/15 11:12 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Been running the NGK BP6ES which is comparable to the old N9Y, anything better and have you seen any advantage either way. Ran N9Y's 35 yrs ago so...,
Been running a 6AL and gap at .045
Thoughts?
Thanks! Bobby
Re: SB bracket racers, what spark plugs you running?
[Re: Streetwize]
#1789775
03/27/15 11:39 PM
03/27/15 11:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I was using the MP Champion 59 race plugs for years in the race car.. 405 ci running 8.90s.. I run the Autolite 3924r on my street/strip 416 ci..
[Re: topside]
#1789777
03/27/15 11:53 PM
03/27/15 11:53 PM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
40 years of racing with Autolite plugs for me. Currently running 3922's in my small block.
[Re: Streetwize]
#1789782
03/28/15 12:32 AM
03/28/15 12:32 AM
Posts: 7,506 Az
Crizila
Az
I like NGK's. Ran ZFR5F in my NA motor and R5671A-9 in my blower motor. Don't know about others, but per NGK, they come with a thread coating out of the box for use with aluminum heads. Don't have to coat with anti-seize, etc. I still use a light oil on the threads.
Fastest 300
[Re: Streetwize]
#1789783
03/28/15 02:13 AM
03/28/15 02:13 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I use 3923's in most. I back cut the ground electrode,set the gap around .035" . As far as durabilty,I pull them every month or 2 , re-gap and sharpen the electrodes,they do wear pretty quickly when making a bunch of passes.
