cooling system wont hold psi ??? #1789480
03/27/15 05:50 PM
03/27/15 05:50 PM
RapidRobert Offline OP
rebuilt/unfired SB. intergrity of the cooling system. how much loss of psi is acceptable (if any). I'm thinking if it is pumped up to 15 lbs it should stay there (or very very close). Your thoughts please
Re: cooling system wont hold psi ??? [Re: RapidRobert] #1789481
03/27/15 06:02 PM
03/27/15 06:02 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
Yes it should hold pressure for quite a while. If it leaks out in less than a hour to nothing then you have a leak that will seep water.
Re: cooling system wont hold psi ??? [Re: mod5v] #1789482
03/27/15 06:14 PM
03/27/15 06:14 PM
Thanks bro, I was afraid of that, alright I'll dig back into it, again
Re: cooling system wont hold psi ??? [Re: RapidRobert] #1789483
03/27/15 06:17 PM
03/27/15 06:17 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Check your pressure checker on a known good cooling system first, many testers leak over time.
Doug
Re: cooling system wont hold psi ??? [Re: dvw] #1789484
03/27/15 10:18 PM
03/27/15 10:18 PM
Yes my Stant pump up kit is a bit leaky but on this I drilled/tapped the stat housing extension for a brass schrader valve & pumped it up directly with an air hose/chuck from the compressor. What I am really after is to find out if it is the head gasket(s) or the intake gasket(s) so if it is the intake gaskets (whichever side) then I dont have to pull the heads
Re: cooling system wont hold psi ??? [Re: RapidRobert] #1789485
03/27/15 10:56 PM
03/27/15 10:56 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Is it full of coolant? If not and you are just using air you could use a soap and water mix and spray it on the possible leak areas and look for bubbles. Tire leak check could also work.
Re: cooling system wont hold psi ??? [Re: NITROUSN] #1789486
03/27/15 11:54 PM
03/27/15 11:54 PM
No coolant cuz I know I have a problem. I've used dish soap/water on the outside to check for bubbles but the inside is where I am focused now. What is "tire check", cuz if that is something that will show up on the outside like smoke or a dye & not need to be cleaned out then that sounds like exactly what I need
Re: cooling system wont hold psi ??? [Re: RapidRobert] #1789487
03/27/15 11:58 PM
03/27/15 11:58 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Tire check is a liquid mixed with water. It really bubbles when there is a leak. It can leave a residue. How can you see the underside of the small block intake coolant passages?
Re: cooling system wont hold psi ??? [Re: NITROUSN] #1789488
03/28/15 12:07 AM
03/28/15 12:07 AM
Yeah I would not want to introduce water into there. To ans your Q accessing the block dist hole would let me checkout the (2) rearmost cooling passages between head/intake. A shop here has a smoke machine that pumps it in to 5 psi he said & it'd be 1/2 hr shop time ($40). I might just bite the bullet & replace both head/intake gaskets & if that dont do it then the tcover gasket.
Re: cooling system wont hold psi ??? [Re: RapidRobert] #1789489
03/28/15 12:25 AM
03/28/15 12:25 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
How much PSI did you pump into this motor Rob?....it's easy to blow out the water pump gasket on a small block with just 20 psi
Re: cooling system wont hold psi ??? [Re: DAYCLONA] #1789490
03/28/15 01:48 AM
03/28/15 01:48 AM
I did 20 as I was thinking that if a regular cap opens at 15 & actually not sure why I went 20. Maybe I should (first) pull the pump then the tcover. Sound like a good move?
Re: cooling system wont hold psi ??? [Re: RapidRobert] #1789491
03/28/15 01:59 PM
03/28/15 01:59 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I have to ask. What made you check this in the first place? Was there a previous coolant leaking problem before the fresh rebuild? Did you deck the block and cut the heads hard and not cut the intake face on the head. Are the heater lines connected or just looped back to themselves? Some more info could help...
Re: cooling system wont hold psi ??? [Re: QuickBpBp] #1789492
03/28/15 08:39 PM
03/28/15 08:39 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
It should hold pressure a long time. I tested a big block that was losing coolant. Tested cold, it held pressure for 12 hours overnight. 16 psi and didn't bleed off a single pound. When hot though, it leaked coolant into the chamber and sent it out the pipe as steam.
If you can't maintain ANY pressure, definitely need to dig deeper
**Photobucket sucks**
Re: cooling system wont hold psi ??? [Re: QuickBpBp] #1789493
03/28/15 10:04 PM
03/28/15 10:04 PM
BP I did Sanborns' cooling mods drilled more/larger holes in block/heads/gaskets and I had to have machined 3/16 alum spacers so the intake would line up with the bolt holes in those chinese fake EQ heads that that crook Ben Gorman of "Promax" in indianapolis sold me. something told me to be proactive & pump it up & I think some of the holes I redrilled/added were a bit too close to the bolt holes and or fire ring not sure on that, nothing obviously fubared but some I cut it a bit too close. My birthday is tomorrow (64) & some birthday money came in the mail today so I am going to rent a hooker (yes I will watch for adams apples/police stings, thanks guys for the heads up on that for last b day, you guys have my back ) and order some new head/intake gaskets & start over & be a bit more meticulous (I'm OCD as it is but I have to take it to a new level on this rare leaker that has baffled me. 70cuda aggreed it should not be leaking down more than a fraction of a lb to my way of thinking. Thanks guys
Re: cooling system wont hold psi ??? [Re: RapidRobert] #1789494
03/30/15 10:46 PM
03/30/15 10:46 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Their cheaper than a wife and they never get fat...
Re: cooling system wont hold psi ??? [Re: minivan] #1789495
03/30/15 10:55 PM
03/30/15 10:55 PM
Yes my intake gaskets & one head gasket (I already have a spare new one) will be in tomorrow (Tues) morning .
Re: cooling system wont hold psi ??? [Re: minivan] #1789496
03/30/15 11:43 PM
03/30/15 11:43 PM
BDW Offline
BDW  Offline
So true, if it flies, floats or f*cks, rent, don't buy
Re: cooling system wont hold psi ??? [Re: BDW] #1789497
03/31/15 01:06 AM
03/31/15 01:06 AM
Western Md.
skicker Online tonguue
"The Champ"
skicker  Online Tonguue
"The Champ"
Western Md.
Robert...She's not getting paid for her actions...She's paid to leave....
...FAFO...
Re: cooling system wont hold psi ??? [Re: skicker] #1789498
03/31/15 03:05 AM
03/31/15 03:05 AM
She got paid for her actions & even tho she was expected to leave actually I was (sorry) to see her leave. Right now everything is good in the 'hood . Tomorrow the heads/intake will be coming (back) off for the third time
