69 b body sending unit fuel in tank question #1789000
03/26/15 07:17 PM
03/26/15 07:17 PM
bethlehem pa
mikemee1331 Offline OP
bethlehem pa
my tank has 10 gallons in it right now. can the sending unit be removed without a flood? in looking at pictures it looks as though it would need to be 3/4 full to be a problem.
Re: 69 b body sending unit fuel in tank question [Re: mikemee1331] #1789001
03/27/15 01:07 AM
03/27/15 01:07 AM
florida
E
edmopar440 Offline
edmopar440  Offline
E
florida
GOING TO BE CLOSE
Re: 69 b body sending unit fuel in tank question [Re: mikemee1331] #1789002
03/27/15 01:24 AM
03/27/15 01:24 AM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
If you are replacing the sending unit let me know if you ever get one that reads correctly. I have gotten two so far that read 1/4 tank off. No matter what i do to try to fix it i cant.
Re: 69 b body sending unit fuel in tank question [Re: mikemee1331] #1789003
03/27/15 01:30 AM
03/27/15 01:30 AM
Michael, I'd do some more cruisin
Re: 69 b body sending unit fuel in tank question [Re: MidPenMopar] #1789004
03/27/15 09:33 AM
03/27/15 09:33 AM
bethlehem pa
bethlehem pa
yep that's what I've done and nope, it's a 1/4 off. it's one of the newer, new repro's. I won't get into the ohms and all but it appears the float position is off versus the working original. won't know until I pull it back out and hook up a meter outside of the tank.
Robert, then I won't know how much fuel is in the tank. right now I know it's 10 gallons which is a little over half full. new sender only shows under a 1/4. I have an electric pump so it's not a huge issue except i'm running out of vacation time
Re: 69 b body sending unit fuel in tank question [Re: mikemee1331] #1789005
03/27/15 09:57 AM
03/27/15 09:57 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Slide the filler tube out and peer inside with a flashlight. You'll see exactly where the fuel level is in relation to the sender. You can reach the float and raise it with a broomstick to measure ohms at different float levels while this sender is still installed.
Re: 69 b body sending unit fuel in tank question [Re: Pynzo] #1789006
03/27/15 10:33 AM
03/27/15 10:33 AM
bethlehem pa
bethlehem pa
ah! we think alike! no dice on pulling the tube out without turning it into a major job. i'll just pump out half of what I put in. i'm re-plumbing anyway
Re: 69 b body sending unit fuel in tank question [Re: mikemee1331] #1789007
03/27/15 12:13 PM
03/27/15 12:13 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Has anyone tried readjustment of the gas gauge to tune it to these repop senders? I have a box of 68-70 B Rally gauges and they have small adjustment holes in the back to move the pointer.
Re: 69 b body sending unit fuel in tank question [Re: Pynzo] #1789008
03/27/15 12:33 PM
03/27/15 12:33 PM
MidPenMopar Offline
MidPenMopar  Offline
All i have tried is trying to change the position of the float arm. I had it cut down a little and that helped some but not much...I had no idea about the gauge adjustment though?
Re: 69 b body sending unit fuel in tank question [Re: MidPenMopar] #1789009
03/27/15 12:44 PM
03/27/15 12:44 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I'll post some pics of these junk gauges tomorrow. Some have the faceplate removed so you'll be able to see what moves with the adjuster mechs.
Re: 69 b body sending unit fuel in tank question [Re: Pynzo] #1789010
03/27/15 02:20 PM
03/27/15 02:20 PM
bethlehem pa
bethlehem pa
interesting...
I just drained, pulled, and ohmed both units to get float positions and ohms as close to each other as possible. put the new sender back in, refilled with the 10 gallons and I only gained 1/2 a quarter of a tank. I went from being under a 1/4 to just over. doing this out in the cold on your back is no picnic!
I don't have a ralley cluster but I do have a spare non ralley cluster and i'll look at what you suggested.
Re: 69 b body sending unit fuel in tank question [Re: Pynzo] #1789011
03/28/15 12:05 PM
03/28/15 12:05 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
This gauge has seen better days- the thermal wire has burned due to a bad voltage limiter. The adjuster teeth are easily turned with a small blade and change the position of the pointer.
I figure that a gauge can be fine tuned to the sender prior to installation by hooking up a circuit with a 3 volt power source and enough 18 gauge wire to match what is in the vehicle. Set the sender for empty and adjust pointer to far edge of E mark on gauge, raise sender arm to full stop and adjust pointer to far edge of F mark, recheck E setting, and you should be done.
Unfortunately you'll need to remove the gauge from the cluster to do this.
Edit- this pic is of an Oil or Temp guage- Gas guage internals are slightly different but work the same way.
Re: 69 b body sending unit fuel in tank question [Re: Pynzo] #1789012
03/28/15 12:08 PM
03/28/15 12:08 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Backside pic
Re: 69 b body sending unit fuel in tank question [Re: Pynzo] #1789013
03/28/15 12:40 PM
03/28/15 12:40 PM
bethlehem pa
bethlehem pa
thanks but like you pointed out, a whole lot of work in a together car. I looked at my spare non-ralley cluster and decided just taking THAT apart wasn't worth the effort let alone pulling mine out of the dash!
Re: 69 b body sending unit fuel in tank question [Re: Pynzo] #1789014
03/28/15 01:32 PM
03/28/15 01:32 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You need 5 volts. The gauges were calibrated in 3 different modes. E-1/2-F. There is a factory tool that allows you to do so. It is just a ground with resistance for each mode. I have that tester and I can measure each mode for anyone trying to tune your gauge. Then all you need is a resistor or resistors to equal that OHM for calibration. The factory manual should have a write up as I remember it instructing you how to do it. If you adjust it for just one mode as mentioned above it will or can affect the other gauge readings.
Re: 69 b body sending unit fuel in tank question [Re: NITROUSN] #1789015
03/28/15 02:25 PM
03/28/15 02:25 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Looking at a '70 Charger/Coronet FSM, it lists a tester, C-3826 for the gauges, with low medium and high settings. The section on Fuel Tank Sending Units has a figure of 73 ohms empty,+or- 12 ohms. Full setting 9.6ohms +or-1 ohm.
What are the values of the L,M, and H settings for the tester?
Re: 69 b body sending unit fuel in tank question [Re: Pynzo] #1789016
03/28/15 02:27 PM
03/28/15 02:27 PM
N
NITROUSN Offline
NITROUSN  Offline
N
When I get out in the shop I will measure the OHM'S of each setting.
Re: 69 b body sending unit fuel in tank question [Re: Pynzo] #1789017
03/28/15 02:43 PM
03/28/15 02:43 PM
bethlehem pa
bethlehem pa
my original was 68 at E and 13 at full FWIW. E on the gauge was always below the line and full a little above.
Re: 69 b body sending unit fuel in tank question [Re: mikemee1331] #1789018
03/28/15 02:59 PM
03/28/15 02:59 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
How about the readings for your new unit? By factory specs a range of 85-61 ohms would make a difference in gauge readings and who knows if your gauge ever recieved a voltage spike due to a faulty limiter. I've got a box full of burned gauges picked from junkyard crawls in the mid '80s. How old is your gauge? How's the voltage limiter and wiring/connections?
I installed what I was told was a "Premium Stainless Life Time Warranty Unit", it bench tested in specs and when installed and wet, has a dead spot right in the middle where the resistance values barely change between 1/4 and 1/2 tank. Haven't bothered to fill it yet, but lifting the float to full stop with a broom handle thru the filler opening,Full reads 3/4 on my old gauge.
I picked up a new Spectra unit and it too bench tests in range and will install it along with a modern gauge setup.
Re: 69 b body sending unit fuel in tank question [Re: Pynzo] #1789019
03/28/15 03:14 PM
03/28/15 03:14 PM
bethlehem pa
bethlehem pa
I don't really suspect my gauge. it's read the same for 30 years with the old unit and prior to this car I had another (non-ralley) and it too read the same.
i'm going to answer the rest of your question over in the other thread I started on the new unit to kinda corral the whole thing. a very un-moparts thing but......
https://board.moparts.org/ubbthreads/show...e=0#Post8406855
