Is a Demon 850 too much carb for a 383? #178883
12/30/08 03:18 PM
12/30/08 03:18 PM
KS
MoparKansas Offline OP
KS
My brother has 383 that is .030 over, 10.5:1 compression and a 510/292(? - going from memory) hydraulic cam with a stock intake. He can get a decent deal on a Demon 850 carb that is slightly used (about the same price as a new Edelbrock 650). Will that be too much carb for this combo or will he be able to tune it down and make it work?
Re: Is a Demon 850 too much carb for a 383? [Re: MoparKansas] #178884
12/30/08 03:20 PM
12/30/08 03:20 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Should be able to tune it down but what's up w/ the stock intake??? get a good dual plane on that thing.
Re: Is a Demon 850 too much carb for a 383? [Re: MoparKansas] #178885
12/30/08 03:56 PM
12/30/08 03:56 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
I would use a 750 D.P. and a different intake.
Re: Is a Demon 850 too much carb for a 383? [Re: Mr.Yuck] #178886
12/30/08 04:03 PM
12/30/08 04:03 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Seems I've heard it's easier to overcarb w/ a Holley than a Carter/E-brock, but I won't have a Holley (never been able to make one work well). Anyway, before the flame wars start, my very mild 383 is running well with an 800 AVS on it, so the airflow capability isn't that much different and he's got a whole lot more cam and compression than I do. So... I guess I'm saying I'd think it should be workable.
: DISCLAIMER : Remember, this from a guy that cannot make any kind of Holley carb run well, period.
Mike
Re: Is a Demon 850 too much carb for a 383? [Re: MoparKansas] #178887
12/30/08 04:15 PM
12/30/08 04:15 PM
AndyF Online content
AndyF  Online Content
He'll probably be happier with a smaller carb.
Re: Is a Demon 850 too much carb for a 383? [Re: MoparKansas] #178888
12/30/08 04:17 PM
12/30/08 04:17 PM
La Verne, CA
lakerism Offline
lakerism  Offline
La Verne, CA
I have a Demon 750 DP w stock intake and similar cam on my 383 and it runs great.
Re: Is a Demon 850 too much carb for a 383? [Re: AndyF] #178889
12/30/08 04:18 PM
12/30/08 04:18 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Smaller carb will need a tweak or two (pump shot, idle misture)- Bigger carbs gonna need some calibrating and trying out. Depends on how much hands on he wants to do.
Keep old mopars alive.
Re: Is a Demon 850 too much carb for a 383? [Re: MoparKansas] #178890
12/30/08 05:54 PM
12/30/08 05:54 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
Demon carbs are wet flowed so the 850 would compare to a 900 Holley or AVS type carb that is dry flow rated.
I tried a 725 Road Demon on a 360 that is 10.6:1 with a Comp XE268H cam with 509/512 lift and I could never get the engine to run will below 2000 rpm. Ran like stink on the top end but I spend so little time on the top end that low rpm manners are much more important. I tried a bunch of different carbs and settled on a 670 Holley Street Avenger.
I would tell your brother to pass on the 850 Demon. You can likely get it to work but its not going to be the best choice. BG even recommends a 650 for his application.
Its going to take a very talented carb tuner to get decent driveability with the 850 on a relatively mild 383.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: Is a Demon 850 too much carb for a 383? [Re: MoparKansas] #178891
12/30/08 06:04 PM
12/30/08 06:04 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
This would be my suggestion...
http://cgi.ebay.com/ebaymotors/650CFM-Ho...emZ260331789414
If he wants some other holley, that seller is Holley & they have some great buys in their Ebay store...
I recently bolted one on my stock 383 in my Challenger, OOTB it ran better then any other carb I'd tried & much better than a Edelbrock 750 that had never eally impressed me though I had improved it considerably from when it was new by fattening the jetting..
I wound up jetting the Holley two steps leaner & upping the secondary squirter two sizes...
Re: Is a Demon 850 too much carb for a 383? [Re: MoparKansas] #178892
12/30/08 06:25 PM
12/30/08 06:25 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
I have 2257 Sealed Power pistons that maybe make 9:1 compression in my 30 over 383 with a Performer RPM and 282S cam.
The 850DP was bolted on with no tweaks and ran fine.
No bog nothing like that, either on the street or at the track. It replaced an Eddy 750 that I really came to hate.
If your bro has that kinda squeeze buy him a better intake for his Bday.
Re: Is a Demon 850 too much carb for a 383? [Re: GwaiiEagle] #178893
12/30/08 07:08 PM
12/30/08 07:08 PM
Central NC
gch Offline
gch  Offline
Central NC
It will work but would likely have better throttle response and need less adjusting with a carb more suited to his setup.Things like converter,gear,and driving style should be considered also.I would think an AVS 800 or a 700/750 DP would be better.
A performer rpm would be a nice upgrade before any carb swap.
Re: Is a Demon 850 too much carb for a 383? [Re: MoparKansas] #178894
12/30/08 07:20 PM
12/30/08 07:20 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
I'D go with a smaller carb.700-750 cfm.
you'll get better response.
lose that stock intake first.
Re: Is a Demon 850 too much carb for a 383? [Re: ohiodemon] #178895
12/30/08 07:56 PM
12/30/08 07:56 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
Buy the 850 and work a trade for a 750 and an intake manifold.
Re: Is a Demon 850 too much carb for a 383? [Re: MoparKansas] #178896
12/30/08 10:28 PM
12/30/08 10:28 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
As said, I think the 850 is too big.
I ran a 750 mighty demon on my 440. FWIW, I thought I might be under carbed, so I replaced it with a BIGS 950 hp, and it didn't go any faster.
The key here, is what series of demon are we talking about?
An 850 speed demon on this 383 is a complete waste of time. You will hate it.
An 850 mighty demon, will work, but the 750 mighty is a waaayyy better pick
Re: Is a Demon 850 too much carb for a 383? [Re: dave571] #178897
12/31/08 01:49 AM
12/31/08 01:49 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I do agree it can work but a smaller carb would be better on that combo. We run a basic Holley 750 DP on my sons 400 in his Dart and it loves that carb. He tried an 800 DP and a 830 anular DP carb and it was still fastest with the 750. I did do some minor tuning on the 750 but nothing much. It has the best low end with the 750 and has run 11.40's @ 117 with the 750. Unless you are getting it for a very good deal I would try for a 750 DP. Ron
Re: Is a Demon 850 too much carb for a 383? [Re: 383man] #178898
12/31/08 08:16 AM
12/31/08 08:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
750DP is probably the best all around carb you can get. It will work on a varity of engines. And it can easily be tuned up if performance goes up.
Re: Is a Demon 850 too much carb for a 383? [Re: Mr.Yuck] #178899
12/31/08 09:52 AM
12/31/08 09:52 AM
moparkc Offline
moparkc  Offline
I am the not so bright brother who thought bigger is better on the carb, had a 750 edelbrock on this engine and it ran pretty good but needed it for my 70 RRunner. I will take the consensus here and get a Performer RPM intake and a 650-750 carb depending on what I can find reasonably $$. If anyone has interest in BG 850 in great shape with electric choke it is for sale now, please PM me. Do not post much on here as I am not brightest about things, BUT Moparts and its members ROCK.
Re: Is a Demon 850 too much carb for a 383? [Re: farmington] #178900
12/31/08 10:42 AM
12/31/08 10:42 AM
Andrews,In. U.S.of A.
67_Satellite Offline
Are you a decent negotiator, because thats what I immediately thought.Someone out there really "needs" that bigger carb., and will be willing to pay to upgrade. You may score a little extra cash or some parts along the way as well.If it's a deal,and you don't need it today,buy and barter.
Re: Is a Demon 850 too much carb for a 383? [Re: 67_Satellite] #178901
12/31/08 11:06 AM
12/31/08 11:06 AM
moparkc Offline
moparkc  Offline
I already bought the Demon 850 and tried it. Too much carb for engine. If anyboddy has smaller carb and /or better manifold to trade or would like this carb let me know. thanks
Re: Is a Demon 850 too much carb for a 383? [Re: AndyF] #178902
04/17/10 11:58 PM
04/17/10 11:58 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
100%
Thanks Andy for realizing the driveability factor
in the combo!! Smaller would be better.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
