MIN WALL THICKNESS
#1788982
03/26/15 07:05 PM
03/26/15 07:05 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I have a customer who just bought a motor from someone out of state. well it never made one full run on the dyno and we had problems. I took it a part and had the walls sonic checked and was wondering what the standard is for min wall thickness. Thanks
JAKES AUTOMOTIVE
Re: MIN WALL THICKNESS
[Re: AndyF]
#1788984
03/26/15 07:10 PM
03/26/15 07:10 PM
JAKE68
Shelby mi.
Thanks Andy, this thing is a street motor and they range from .113-.165.
JAKES AUTOMOTIVE
[Re: JAKE68]
#1788985
03/27/15 12:56 AM
03/27/15 12:56 AM
Posts: 43,237 Bend,OR USA
Cab_Burge
What bore size and which year block, B or RB also, is it? I like to see at least .160 or thicker on both the minor and major thrust sides and no thinner than .120 anywhere else like AndyF says I did a sonic test for a customer in SO CA back in 2001,2002 era on a 1976 400 block and it had .117 at the thinnest part of a rear, bellhuousing side, lower cylinder wall. That was before boring it, I advised him to find a better block but he built that one anyways, it made around 550 HP and went 145 MPH in a 2300 lb S/G Daytona
[Re: Cab_Burge]
#1788986
03/27/15 12:51 PM
03/27/15 12:51 PM
JAKE68
Shelby mi.
This thing is a .060 x 4.0 stroke 360. On the thrust sides it is .111-.175
JAKES AUTOMOTIVE
[Re: JAKE68]
#1788987
03/30/15 01:34 PM
03/30/15 01:34 PM
Posts: 8,302 fredericksburg,va
cudaman1969
fredericksburg,va
I was hoping you would say the 5.7 Hemi block. I'm interested in seeing how thick they need to be after boring.
[Re: dogdays]
#1788990
03/31/15 02:56 PM
03/31/15 02:56 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
0.111 on a thrust side with a stroker crank (= more side loading) would put me off the block, unless there was so much machine work invested that it'd be cheaper to put in a couple sleeves.
0.150 on the thrust and 0.100 on the non-thrust would be my limits.
R.
Those are my minimums too. I used to want more - but it was almost impossible to find a block with all the holes that good.
